Old 05-12-2015, 10:08 AM
Cobra Make, Engine: Kirkham 592
Default What do you guys use for a floor jack?
I want to buy a good quality jack. I was thinking of a Compac. They are made in Denmark but their min height is 3.5 inches. Will that fit under the car?
Old 05-12-2015, 10:50 AM
I have a Harbor Freight 6 ton floor jack that works great. It just barely fits under the frame from the side, but enough to get it positioned. They also offer a low profile aluminum jack that would be great but I needed a jack large enough to also lift my truck and other vehicles if necessary.
Old 05-12-2015, 11:12 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Check out the AC low profile jack DK20. 3.15". Not cheap but it's very high quality. Find it at Pelican Parts.
I also got Acton's jack attachment for round tube frames.
rodneym
Old 05-12-2015, 04:55 PM
Harbor freight 1.5 ton racing jack. Easily fits under your cobra. $89.
http://m.harborfreight.com/15-ton-co...ump-62160.html
Old 05-12-2015, 06:21 PM
Hotfingrs's Avatar
This is the one I use from Harbor Freight. Easily fits under car and has enough lift for my kwik lift Low Profile Floor Jack - 2 Ton, Rapid Pump® Jack
Jack
XSSIVE .....
Old 05-12-2015, 06:43 PM
DAVID GAGNARD's Avatar
1.5 Ton Compact Aluminum Racing Floor Jack with Rapid Pump®
I have this one also and the next size larger,maybe 2 or 2.5 tons,aluminum jack also......the big is about shot as it has been used and abused for 10 years now.......the pump needs rebuilding....
the smaller one is not as old and has not been abused like the bigger one, really satisfied with both of them.......
DAVID GAGNARD
Old 05-12-2015, 09:11 PM
legenmetals's Avatar
I use the harbor freight low profile 2 ton jack at the race track instead of the 3 ton. It reaches further into the car but loses some of its rating. About 2-3/4 height. It's an offshore unit but gets the job done.
Old 05-12-2015, 09:47 PM
twobjshelbys's Avatar
Are you a professional shop with the jack being used 20 times a day or just a hobbyist and use it monthly or less? If the latter, get the low profile jack from Harbor Freight. My friend with a commercial shop got one for "low profile" cars that come in and loves it.
CSX4005LA
Old 05-12-2015, 11:08 PM
fordracing65's Avatar
Harbor Freight low profile jack, costs under $100...
PRIDEnJOY
Old 05-13-2015, 03:59 PM
427sharpe's Avatar
Same here...HF low profile aluminum w/ rapid pump. Works great, easy to stow, and reliable. Paid $69 @ 4th of July tent sale.
Old 05-13-2015, 06:28 PM
I have a 100 plus lb lincoln floor jack. A real PIA to move around. Get a lightweight aluminum jack unless you are a professional shop using the jack all day long.
Old 05-13-2015, 07:03 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Norco Quality
If you only use a jack once a twice a year, maybe the Harbor Freight unit will hold up, they aren't really known for quality and generally are not rebuildable.
If you a quality, rebuildable jack, take a look at the Norco 71233A
Website and further details
The jacks are rebuildable, 1 yr warranty and low enough to get under our cars.
The customer service people at Norco can point you to a local distributor. (800-347-2232)
I've used one for eight years and extremely pleased with it.
www.65shlb.com
www.prdcrrct.com
Old 05-13-2015, 08:39 PM
I have a 30 by 40 shop and several cars that need a low profile check. I want reliability. I do not need an aluminum Shack. I prefer steel. I have heard that compact are exceptions anyone use one of them
Old 05-14-2015, 01:36 AM
I Paid an extra $5 for a warranty, ever year I can bring it back no questions asked and get a new jack for no reason, great deal....
most of their stuff is take back get new no questions asked just buy the little warranty..
PRIDEnJOY
Old 05-14-2015, 07:40 AM
Cobra Make, Engine: ERA 714
I used the Jegs two ton version.
http://www.jegs.com/images/photos/500/555/555-80006.jpg
Phil
Old 05-14-2015, 12:47 PM
cycleguy55's Avatar
Torin Black Jack 2 1/2 ton aluminum / steel. It's like this one, but with red side plates instead of blue: http://www.costco.ca/Torin-2.5-Ton-A...100212713.html
Minimum height: 10.5 cm (4.125 in.)
Maximum height: 46 cm (18.125 in.)
Weight: 24.9 kg (55 lb.)
IIRC I paid CAD$99 4-5 years ago. Works like a charm.
Brian
Old 06-27-2015, 10:48 PM
I went with a Pittsburgh jack. I purchased the 2 ton low profile and used it for the first time yesterday. It was a nice jack. I bought the steel version. Nice and HEAVY and did a good job. We will see if it holds up
Old 06-28-2015, 08:03 AM
ZOERA-SC7XX's Avatar
The Harbor Freight 2 ton low profile aluminum racing jack has been good for several years of service on the cheap for my Cobra and the race cars, but for my trucks and larger cars I use an old steel Sears Craftsman (slow pump) that I've had for thirty-five years. However, if you have a commercial shop, you have to spend the bigger bucks for quality.
Old 06-28-2015, 11:19 AM
Mark Brye's Avatar
I have had a couple of the aluminum HF jacks. They are light and have smooth operation. But if you use them on a full size truck, they will blow out there seals. I had one last a year and another go six years. If I would have only used them on the cobra, I am sure they would have lasted. Now I have an Arcan xl2 which is very long and sits low at 2.5 inches. But it is over a 100 pounds which stinks if you have to pick it up. I like the length because I can get to the frame rails before the main body gets to the pipes. The negatives of this jack is the saddle is small and does not have a pad?
Old 06-28-2015, 12:38 PM
Thor maine's Avatar
Sears Craftsman 3 ton shorty. It is an older one, when Sears actually made quality tools.
