November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 05-01-2016, 09:56 PM
Club Cobra Member
Cobra Make, Engine: Kirkham/Southern 427 SO finally on the road
Default Best Hydraulic T/O Bearing for #174..
My HTOB is leaking...%*&^@&*^%$%. The car has a correct cast FE '65 SO, 4 speed top loader, McLeod Bell housing. What's the most reliable and least likely to leak of those available? thanx. s
steve meltzer
"I may be wrong, but I'm never in doubt"
Old 05-02-2016, 03:33 AM
xb-60's Avatar
Good question. I'm all ears. I need one too.
Glen
Old 05-02-2016, 04:10 AM
The most reliable is a traditional throw out bearing, clutch fork, and hydraulic slave cylinder.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 05-02-2016, 04:30 AM
Club Cobra Member
I tried that initially, and we made a great effort. I'm not an expert on this, but we could never get it right (adjustment and function wise). From the get go when i got my car (an early car, as you can see) David K. said to use a hydraulic T/OB. Finally, in desperation, I bought one from him and it worked great...'till now. s
steve meltzer
Old 05-02-2016, 06:54 AM
MOTORHEAD's Avatar
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Did you have a pedal max travel stop installed ? The HTOB's don't have an internal stop, so pushing the pedal too far will extend the piston past the seal and leak or dump most of fluid. It happened to me, but I knew better, so shame on me.
I converted to external slave (the purple one from Speedway Motors) a throwout arm and a clutch disc from McLeod.
I'll try to find pics.
The HTOB's work better IMHO, (less pedal pressure ) but must be set-up as per instructions or you will have problems.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
Old 05-02-2016, 08:14 AM
Cobra Make, Engine: Kirkham #259
Tilton....
Morris
Old 05-02-2016, 02:32 PM
Club Cobra Member
thanx for all of the info. may go back to the mechanical bearing with a slave. thanx again. s
steve meltzer
