12-31-2016, 07:01 PM
Cobra Make, Engine: Kirkham
Kirkham side pipe mounting
I just finished mounting my kirkham stainless side pipes. I am posting this to help others in the future.
First, convention has the Ford FE cylinders numbered 1 through 4 on passenger side, and 5 through 8 on driver's side. this is different than chevy conventions
when connecting the passenger side, I loosely mounted #4 and then #1, and then did 2 and 3 last. they went in easily from outside the body, but I did not have the starter in position. just a little moving them around. Of note, I had them wrapped in paper from the polisher, so no scratches on insertion
The driver's side was more difficult. The correct sequence turned out to be:
first #8, then #5. then 7 and then 6. can't do 6 then 7. ask me how I know. also had to remove the steering shaft to get them in, but then it wasnt so bad
for attaching the side pipes to the header tubes, i put lots of grease in the sidepipes, and then worked them in, with the header tubes very loose on the engine. it all fit really nicely. It seems anything I get from Kirkham really is well engineered - I am so used to aftermarket parts NEVER fitting properly from my previous experiences with everything else I have done.
I will include some pictures soon. happy new year to all
12-31-2016, 07:07 PM
Full Blown Member
Nice write up!
They are a bit tricky.
rodneym
01-02-2017, 02:10 PM
here are just a few pics of the installed pipes. i originally planned to do unpolished stainless (have to save some money somewhere), but the pipes unpolished are not so attractive, and they look absolutely fantastic when polished, so I did that.
i planned to polish myself, but after 30 minutes of work and almost no progress, I found a local polisher who did a great job for a lot of money (although, as with polishing the entire car, still probably better off paying someone else to do it than doing it myself)
01-02-2017, 07:52 PM
How do you know which headers are which??
PRIDEnJOY
01-03-2017, 04:02 AM
the cylinder number is stamped on the mounting flange for each individual tube
01-03-2017, 02:33 PM
Easy enough
PRIDEnJOY
01-06-2017, 04:58 AM
Very nice !!
Dan
427 CSX 3000/4000 and Shelbys.
All gone ! Was a Hell of a run
Now ... The dogs car
Mercedes E63S station wagon. 603hp
01-06-2017, 05:38 AM
Yep - that Ford cylinder numbering convention has tripped up more than one old Chevy guy on header assembly. They look nice.
01-06-2017, 09:02 AM
Here is what my unpolished SS headers look like after less than 2K miles:
Your polished headers will discolor from heat as well. I'm going to have mine ceramic coated, which is cheaper than polishing and will not discolor. They can be done to look almost chrome like, but I'm going to simply go with black for maximum cooling benefit in the engine bay.
