December 2025
Old 12-23-2006, 07:45 PM
Cobra Make, Engine: KMP 498
Default Oil Pan Clearence?
What is the deepest oil pan I can have on AN FE'd Kirkham? Looking for distance from bottom of block to the bottom of frame rails.
Seems like some guys are runnung stok pans which are about 5 1/2 inches. I want to use a truck oil pan which is 6 1/4 in. Mainly because they are almost industrictable from a hit.
Old 12-23-2006, 07:57 PM
Banned
May I suggest using the original style 12 quart pan from Aviad .It fits ,It works, and it is bullit proof for about 500 bucks
Old 12-23-2006, 08:32 PM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
I have the aviad and would caution you that using a pan deeper than 6" may cause the pan to be lower than the frame rails. At least that is the measurement on mine. Pond block.
Old 12-23-2006, 10:10 PM
Thanks, that is what I needed to know. I do not want to be below the frame.
Old 12-24-2006, 05:24 AM
427 S/O's Avatar
I had a few idea's during the build to make the beast handle a little better, one was to lower the engine. The T-pan was about 2 1/2 inches below the frame so, I added teflon skids for protection...works great, although I will never be able to navigate speed bumps...about the only time they rub is when I'm at a good speed and hit a low spot in he pavement.
See my pics...
Perry
Old 12-24-2006, 05:58 AM
Cobra Make, Engine: CSX4000, 427
I agree, the bottom of the pan is even with the bottom of the main frame rails, crossmember, using the standard engine mounts. I believe there may be the possiblity of using other, lower engine mounts, and you may have to run a dry sump with that application
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
Old 12-24-2006, 06:17 AM
double ugly's Avatar
Armondo's Racing pan is a good alternative to Aviad. Basically the same pan but cheaper. http://www.streetperformance.com/ind...edlisting=3408
I bought one based on recommendations and couldn't be happier. Their service and support is excellent. Armando worked for Aviad for years before starting his own company.
John
double ugly
Old 12-24-2006, 10:34 AM
Clois Harlan's Avatar
or some of us are running Canton Pans that allow only 3 1/2" of clearance. In almost six years never a problem on or off the track.
Clois
"Let's roll"
"Be part of Something Good
