Old 03-03-2007, 01:06 PM
Banned
Default Coolant catch tank size with FE
How big a catch tank do I need for a Kirkham with an FE. (not the purge tank, but a little tank to put in place so that the purge tank does not drain to the ground) 1.25 quarts enough or do I need a 2.5 quart tank?
Old 03-03-2007, 02:24 PM
Chaplin's Avatar
I bought a 2 qt canton (80-201 on the link below) and I have never even come close to filling it up- in fact, I've never even had it 1/8 of the way filled up. In fact, since I installed it, I think I have almost stopped spilling coolant entirely. You'll find when you first get the motor installed and running, you will dump a little every time you shut it down, but once all the air is out of the system, you will reach a point when there is "balance" in the system and it will stop dumping coolant. If you overheated it would be good to have a larger reservoir, but if you overheated 2 qts wouldn't be enough anyway. Bottom line,1.25 qt is way more than enough.
http://www.cantonracingproducts.com/...tch_tanks.html
Replica is not a dirty word.
Old 03-03-2007, 05:00 PM
Banned
Cool, thanks!
How do you look in it to see the level? Most new cars have see through bottles, so it's easy to see the level. . .
Old 03-03-2007, 05:18 PM
Chaplin's Avatar
If you look at the left side of that picture, there is a clear tube that runs the length of tank which is connected with 2 fittings coming out of the side of the tank. You can see the level through the tube.
Old 03-05-2007, 06:27 PM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Morosso makes a nice aluminium one
I used an aluminum one from Morosso and mounted it forward of the brake fill canisters. Local speed shops have them. [IMG][/IMG]
Old 03-05-2007, 09:02 PM
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
I bought mine from summir - about a quart and have never filled it.
