Old 02-24-2008, 03:57 PM
Cobra Make, Engine: KMP 498
Default KMP 0498 Is Alive!
Started it up around 1:30PM today. Ran it for 10 min at hihger RPM's. Turned if off and started it up and ran for 10min more. No events. I absolutly can't not believe the Pro-Systems carb. I was told not to screw with it and for once I did not- I adjusted the rear float bowel and it even idels around 900RPM's. These guys are serious- this is my first custom carb- I will never use off the shelf again!
Note:
1. Remove any marks on your SS side pipes with thinner before fire up- yes they will Leave a Tatoo.
2. Hook up the crankcase vent system before or you will get oil over the back of engine not much but a mess.
3. It idels at operating temp between 40 & 45 PSI- I did not put in the extra OP spring. Just stright Percision Bluprinted.
4. 3000RPM right at 80psi.
5. With the electric & carter pump I only see 6psi of fuel with the bypass reg. I fooled with it but that was max. I need to figure that out.
No oil leaks or water leaks. The kirkham fan really pulls air.
Old 02-24-2008, 04:25 PM
ROUSHAC's Avatar
A BIG congrats, Bill! That's a job well done.
Dave
Old 02-24-2008, 04:57 PM
RON N BKFLD's Avatar
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
Bill,, let me know when you want to take a run over to Pismo, O yeah, congrats..........Ron
RON N BKFLD
Old 02-24-2008, 05:01 PM
RedCSX1's Avatar
Good Job Bill!
You dont want more than 6 pounds of fuel pressure, otherwise you might cause carb damage. See you on the Road.
Post some pictures.
Morgan LeBlanc
Fresno CA
Old 02-24-2008, 07:01 PM
Jamo's Avatar
Super Moderator
Heeeeehaaaaaawwww...way to go!!
Your oil and gas pressure numbers match mine...you're good to go.
Jamo
Old 02-24-2008, 07:06 PM
JWheaton's Avatar
Cobra Make, Engine: ERA 389 427s/o
Big Boss,
Congratulations on getting the beast heart started up.
Before Wilf gets to you though, please edit "idel" to "idle".
Happy motoring!
Old 02-24-2008, 07:45 PM
Cobra Make, Engine: Cutting Edge, Boss 429
Congrat's Bill.
Have fun.
Chris
Old 02-24-2008, 08:09 PM
Cobra Make, Engine: Kirkham, 482 Shelby / TKO 600
I thought the fuel pressure for a carb motor should be 14-15psi?
Old 02-24-2008, 08:19 PM
Jamo's Avatar
Super Moderator
Mine will go to 7-8 when it's hot outside or at the track...running electrics only.
Jamo
Old 02-24-2008, 08:20 PM
xlr8or's Avatar
Way to go Boss. Enjoy.
Old 02-24-2008, 10:40 PM
RodKnock's Avatar
Great job. Best of luck and hope to see you on the road one of these days.
Old 02-24-2008, 11:39 PM
RedCSX1's Avatar
NOT for carbs. FI has higher fuel pressure.
Morgan LeBlanc
Fresno CA
Old 02-25-2008, 12:56 AM
I stand corrected, the proper fuel pressure for a carb engine should be between 8-9psi.
Old 02-25-2008, 01:23 AM
FatBoy's Avatar
Big-boss,
Are you running the Holley pump that comes with the Kirkham AND a Carter mechanical pump in line?
I also have a Kirkham and I'm not far behind you in the build process. I also have the Kirkham supplied Holley and a Carter mechanical pump and I was advised to get rid of one of them, so I was goung to remove the electric pump. I'd be interested to hear your's and others thoughts.
Paul
Old 02-25-2008, 05:18 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Now the fun begins
When is the first trip around the block to introduce your neighbors to your new toy?
Old 02-25-2008, 06:47 AM
Thanks guys,
FatBoy, Yes, stock Kirkham pump and Carter. I am going to give the boys a call today and see what is up. I think I need more fuel pressure.
Old 02-25-2008, 07:16 AM
Chaplin's Avatar
Congrats Boss, glad all went well. Nothing quite exciting as hearing it start for the first time is there?
Replica is not a dirty word.
Old 02-25-2008, 07:50 AM
We run 6 psi of pressure on the fuel gage. With the bypass set up that should be plenty. Your engine builder may have another opinion though... Lots of our customers run both pumps in line. Electric to mechanical. That provides some redundancy.
One trick with the Holley electric pump:
If you look at the pump as it is mounted in the car. There is a large screw/cap on the bottom of the pump facing the rear. If you pull this cap out you will find a spring. Stretch this spring out to about twice its normal length and then put it back in. This will keep the pumps internal regulator from bleeding off pressure and then you can adjust pressure with the bypass regulator.
Congrats on the start up! Very cool indeed.
Joe
Old 02-25-2008, 09:31 AM
Cobra Make, Engine: owned Kirkham for 11 years
Well worth the wait, Boss
Enjoy
Maurice
Old 02-25-2008, 01:37 PM
RedCSX1's Avatar
Default What size carb CFM? Jet size?
[quote=big-boss;818589]Started it up around 1:30PM today. I absolutly can't not believe the Pro-Systems carb. I was told not to screw with it and for once I did not- I adjusted the rear float bowel and it even idels around 900RPM's. These guys are serious- this is my first custom carb- I will never use off the shelf again!
Boss, What is the CFM size and jets size they have in the primaries and secondaries?
Morgan LeBlanc
Fresno CA
