December 2025
Old 02-07-2009, 04:06 PM
Default Body removal and refit
Does anybody know what is involved too remove a body from a kirkham 427 and then refit at a later time?
thanks
Old 02-07-2009, 04:54 PM
cobred's Avatar
Cobra Make, Engine: ERA #698 428 Toploader
I think the body is mounted like the originals, the alum. skin is folded over the round tube framework and riveted. You would have to drill out the rivets and unfold the alum.to remove it and reverse the process to reinstall. Would probably do more harm then good. Why do you want to?
Old 02-07-2009, 05:20 PM
Im not a kirkham owner, just out of interest really. I had seen pictures of the body work in two pieces, i thought they would have to be either split or joined depending!?
thanks
Old 02-07-2009, 10:19 PM
CC Member / Sponsor
Almost as difficult as making the body in the first place is mounting it to the frame. The body is wrapped around the steel tubes and rivited on. Yes the two clips are put on separately but then they are welded together (typically under the door). When the body is being wrapped around the tube it distorts... When the body is being welded it distorts... For this reason there are very few original Cobras that have frame off restorations, unless something really bad happened to the car.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
