Old 02-17-2009, 03:23 AM
FatBoy's Avatar
Default Should my engine be central?
Hi,
I've just taken the hood scoop off my Kirkham in preparation for rubbing down the bodywork and I noticed that the air filter isn't central to the hole in the hood.
I wasn't sure whether the carb was positioned centrally on the engine, so I thought I'd check the bottom of the engine. I have a Canton oil pan and the gap between the chassis rails and the oil pan wings is different from one side to the other by about 3/4" (the drivers side gap is larger).
This also obviously effects the side-pipes. The drivers side-pipe runs close the the body, whereas the passenger side-pipe is some distance off. I had just put this down to tolerances in the pipe bending, but maybe it isn't.
The engine doesn't seem to want to sit anywhere other than where it is. Am I missing something?
Your thoughts would be appreciated.
Paul
Old 02-17-2009, 04:46 AM
kris-kincaid's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to kris-kincaid Send a message via Skype™ to kris-kincaid
The chassis was designed to offset the engine 1/2" towards the right side. Thats the way it's supposed to be.
Old 02-17-2009, 04:58 AM
FatBoy's Avatar
Thanks Kris.
I was puzzled about how I was going to correct it if it was wrong, but I'm now reassured that all is as it should be.
Thanks again.
Paul
Old 02-17-2009, 05:22 AM
mickmate's Avatar
It helps align transmission and pinion(the pinion is offset), gives a little more footroom on the pedal side and balances the car side to side with the one person who has a roll bar.
mickmate
http://www.actoncustom.com/
Old 02-17-2009, 07:45 AM
FatBoy's Avatar
Having checked the measurements, it is exactly ½" off centre, so you were right on the button Kris.
Old 02-17-2009, 08:05 AM
Cobra Make, Engine: B+B 351w #112
Wasn't it because of the sidewinder intake used on the big blocks? Carb doesn't sit in the middle of the engine. Jim
Old 02-17-2009, 08:28 AM
FatBoy's Avatar
That had crossed my mind, which is why I also checked the bottom of the engine and found that the block was off-centre by the same amount as the carb.
Therefore, I'm happy with Kris and Mickmate's responses.
Paul
Old 02-17-2009, 11:05 AM
CC Member / Sponsor
The small block cars are also offset. This was to reduce the angle on the drive shaft.
Cubic Performance
HiTech Legends
https:HiTechLegends.com
Evolve Lubricants
https://evolvelube.com/
Old 02-24-2009, 06:22 PM
Cobra Make, Engine: 1965 registered Brushed Kirkham polished stripes, 427 FE kieth craft 482 efi.ss chassis and all the go gear .
Bloody good question, i thought it was just my car #385 in Australia.
" And them boys in them Chevy's,are going to say Pipes!!! Look at them pipes !!!- Bill Cosby 200MPH.
Old 02-27-2009, 03:08 PM
David Kirkham's Avatar
Original Shelby Owner
The pinion on the differential is 1.000 inches offset to the right of the car. To keep the drive line angles reasonable, the engine is 1/2" offset to the right of the car. Of course, this makes for some very interesting issues when you are dealing with a right hand drive car!
The 1/2 inch offset is original.
