Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Lone Star Classics---Speak with Dennis & Steve
Old 11-17-2016, 10:34 AM
Cobra Make, Engine: Cobra n Vettes, 1966 Cobray C-3 running gear, 355 SBC TH-400
Default **looking for a Lone Star Body**
Hi - I found a Lone Star 'ladder-style' frame with 3-link rear end - any recommendations for finding a 'tub-style' cobra body that will fit??
Any advise/leads would be GREATLY appreciated
Old 11-17-2016, 06:39 PM
Texasdoc's Avatar
No idea. However, one of the local guys has resurrected the Lonestar forums. You can try there. lonestarclassics.freeforums.org • Index page
Also, you can try UCC. They may sell you just the body. It will probably fit with a little modification.
Old 11-17-2016, 09:28 PM
Dwight's Avatar
Smile
last year I called about buying a new Lone Star body for my old Lone Star frame. It would take to much modify the frame to fit the new body. Cheaper, easier to buy a new frame to go with the new body.
Dwight
I know where there are a few Gentry bodies for sale. Don't know if they will fit
Old 11-18-2016, 07:13 AM
Karl Bebout's Avatar
Nocal, Jeff Classic, in PHX builds big Cobras on C4 frames that are very nice. He might shrink one of them for your frame. You'd have to check with him. 602-402-8504
Karlos
Old 11-18-2016, 08:07 AM
Karl - thanks for the lead - If it's the same Jeff Classic that built the Cobray's I actually have one of his cars!!!! I'm like the 'red-headed-step-child' because it has a SB Chevy with auto, but I bought it for just cruizin' Besides how many 32' Fords are running the same drive train LOL!!! I'll give him a call to see what he can do!
I did find a guy in SoCal *Westcoast Performance and Marine that has a body for $3,500 - I just need to confirm what wheel base my frame is and compare it to his body
Old 11-18-2016, 11:50 AM
Default Body
Call Antique & Colletables (A&C) in Buffalo ask for Joe 7168230007
Jon
Old 11-19-2016, 07:48 PM
Default Thanks for the feedback
Hey Gang,
Thanks for the feedback - I picked up the frame today and not sure if there's enough parts readily available to put this thing together - anyone have some pics of their build / frame / assembly manual etc
Old 11-20-2016, 04:58 AM
Dwight's Avatar
Smile
I might have a Lone Star manual but it's not worth anything. Very generic.
Install motor
install rear end
install upper and lower control arms, etc. No details
As for parts, if you have a body and frame that match then you can buy the "Cobra" parts from Shell Valley or Finishline. The rest of the parts can be bought at the parts stores.
I used a 8.8 from a 89 Mustang and Mustang II front suspension.
If the frame has Lone Star's old Mustang spring mounts, I would strongly suggest you cut them off and add coil over mounts. Go with adjustable coil overs on all four corners. Speedway sells the front upper and lowers control arms.
If you don't have a welder, go buy one.
I have over 1400 pictures of my car, maybe 600 of the build.
Best of luck
Email me if you want. I can send pictures to help answer your questions. Maybe.
18 years ago I started with a $20,000 budget, I stopped counting at $35,000 and guess that I spend $60,000. But I had a million dollars worth of fun.
Dwight algunruner@aol.com
Old 11-20-2016, 04:07 PM
Default update - can't post pics
Hey Gang just a quick update-can't post pics but got confirmation that it's a pre-2006 frame from Brian -
It has coil-overs on all four corners- no rear end, but might have found one for a 78-98 Mustang 3:55 gears + 11.5 cobra discs - not sure of the spline -
Dwight - you might just be my new best friend LOL!!!!! Thanks for the quick response and I'll send you pics of the frame.
If you get board, I'd appreciate some pics of your frame and cowling hoop?
Thanks again - any leads on a UCC GT427 or LS-427 body - PLEASE KEEP ME POSTED!!!!
Old 06-15-2017, 08:15 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Super late on the date, but;
Long star used to use Currie tubes and axles for their rear ends.
Dwight is correct, there was no manual.
Maybe 94 inches on the wheel base.
Hope this helps.
Old 06-16-2017, 05:01 AM
Dwight's Avatar
Smile
The 3.55 gears worked great for me with 26" tires. My small block had a lot of low end torque. With the tranny you will need a 2.97 gear to make first useable gear.
If the frame has coil overs on all four corners then you are off to a good start.
Last winter my pictures file got corrupt and I lost a lot of my build pictures.
NorcalLmo, if you are still out there and need my help just let me know.
Dwight
Old 08-24-2017, 09:29 AM
Default Sorry I've been MIA
Hey Gang,
Sorry I've been MIA - after sifting through the GREAT feedback on these forums and doing the quick math - I decided to go a different direction - Still running my C-3 Cobray and found a Factory Five MK3 that had a little 'bump' on the passenger side front end - found a body and I'm currently 'waiting' patiently for our local cobra 'GURU' to get it back together LOL!!!. If someone has a body - I'd still want to pursue the build on the LS 427 let me know Ldmoore@comcast.net
Thanks again ya'lls!!!!
Old 08-24-2017, 03:40 PM
FWB's Avatar
FWB FWB is offline
Default new body
Lone Star has new digs in Boerne Texas, i believe they have the molds yet
they can make you a fresh body.
Build Your Own Customized Sports Car - GT-427 Roadster - UCC
Fred B
Old 08-24-2017, 04:49 PM
undy's Avatar
Lone Star and UCC are entirely different cars and UCC has NO old Lone Star bodies. They're not even inclined to provide any more support to old LSC customers too.
Too many toys?? never!
Old 08-24-2017, 05:06 PM
FWB's Avatar
FWB FWB is offline
Undy, when did you hear this?
i am at their site a couple times a month and i have never heard that narrative.
yes the new UCC car is different but the old molds are still there to pop new glass
i'm going to be there tomorrow night, i will re-ask the question.....i'll snap some pics if i get the chance
Fred B
