Old 08-09-2008, 05:46 PM
jams's Avatar
Cobra Make, Engine: B & B
Default Aluminum Foil wrapped soda cans ring a bell
I saw a older usher at a baseball game the other night with a plastic soda bottle wrapped in aluminum foil. This brought back memories to when I was in elementary school. Whenever we went on a field trip, we always wrapped our soda/juice cans with aluminum foil. Looking back it seems like a silly/useless practice but we didn't question it back then. We just though it would keep the cans cooler.
Did anyone else do the same thing? Maybe there is some science behind the aluminum foil trick.
Old 08-09-2008, 11:35 PM
Joe Wicked's Avatar
Nope, never heard of it until just now. I can see trapped cold air inside the foil acting as an insulator, but I don't know how much of an effect it would really have.
Why do they call it "Common Sense" when it is so rare?
Old 08-11-2008, 07:14 AM
J. T. Toad's Avatar
Cobra Make, Engine: Classic Roadsters, 351W -> 392
it makes a difference ... especially if you use an entire roll.
(maybe not the best difference, but I don't have a supply of space shuttle tiles)
I remember that foil used to be cheap and a lot thicker.
"Smooth seas do not skillful sailors make"
"If you can read this, thank a teacher....and since it's in English, thank a soldier."
Old 08-11-2008, 09:36 AM
Joe Wicked's Avatar
I didn't think about multiple layers. Multiple pockets of insulators would help keep it cold longer, and likely help keep the cold can from freezing your hand.
Old 08-11-2008, 10:17 AM
HI Cobra's Avatar
Then there were those who thought putting aluminum foil under hubcaps
would make them invisible to radar. Bet that didn't last too long!
Flip
Old 08-11-2008, 10:47 AM
Cobrabill's Avatar
And when your done,you can make tin foil hats.
Old 08-11-2008, 10:56 AM
J. T. Toad's Avatar
LMAO... Did people REALLY think that? I thought it was just a joke from an episode of CHiPs... not that I ever saw that episode, or any episode for that matter.
Old 08-11-2008, 03:16 PM
HI Cobra's Avatar
I am old enough to remember the tin foil in hub cap trick in the late 50's -
early 60's by hearsay - I could see no logic in it. I think the idea may have
come from the Air Force trick of dumping a truck load of foil chafe while
flying to make distracting images to fool enemy radar, which had nothing to
do with putting it on wheels but you know how that goes.
Flip
Old 08-11-2008, 05:38 PM
jams's Avatar
I guess my tin foil around the soda can must be a regional thing.
Old 08-11-2008, 05:43 PM
Buzz's Avatar
Interesting question. The foil may have a slight insulating effect if there is air trapped between the can and the outer layer, but foil is a pretty good conductor by itself so in direct contact with the can it should have little effect. Now, if the can is potentially exposed to a source of radiant heat - sitting out in direct sunlight for example - then the shiny side of the foil could act to reflect some of the radiation and would heat up at a much slower rate than the surface of the can if it is exposed.
I did a search on the topic and the following post came up. Some of what the guy wrote is plausible when talking about grilling and cooking because the foil can indeed reflect radiant heat. When he tries to explain the results of his soda can experiments, however, he talks about the foil reflecting "cold". Cold is not a radiated form of energy - it is simply the absence of heat and can only be "lost" through conduction or "conserved" by insulation. It can not be "reflected"!
( I put those words in quotes because you can't actually lose or conserve "cold" you can only speed or retard heating)
Still, if his story is true - some interesting results:
dalepetrie said:
I see these answers which say either it doesn't matter, or put the shiny side towards the food but it doesn't matter much. I can attest that it DOES make a huge difference. The shiny side reflects, the dull side absorbs. Now yes, on a grill, the heat is so intense that likely what's going to happen is that whatever side faces the flame is going to get blackened, and the heat will go through just as quickly. But when I was in high school lo a couple decades or more ago, I would pack a can of soda for with my lunch. But alas, I had no refrigerator, there was no way to get ice at the school cafeteria, and I couldn't stand warm soda. So, I began experimenting with tinfoil. Here's what I found:
Taking a refrigerated soda - warm by the time I got to lunch.
Taking a refrigerated soda wrapped in foil with the dull side facing the can - coolish by the time I got to lunch.
Taking a refrigerated soda wrapped in foil with the shiny side facing the can - mostly cold, but not as cold as I liked by the time I got to lunch.
Wrapping a soda can in tinfoil, shiny side towards the can - can would freeze completely within an hour, soda still frozen if I didn't take the foil off.
I found two ways to get the soda as cold as it would be if I took it out of the refrigerator. Either take a refrigerated can, put it in the freezer for about 15-20 minutes w/ no foil and wrap it with foil shiny side in, OR, at 10pm, I would take a can, wrap it in foil with the shiny side out, place it in the freezer, then at 7:30 the next morning, I could put it in my bag and at lunch time it was perfect. The shiny side reflected enough cold so that it wouldn't freeze in 9 1/2 hours in the freezer (a regular can put in the freezer with no tinfoil will usually explode within an hour and a half), yet, it would allow enough cold to get in, and keep enough cold in over the next 4 1/2 hours to make it the perfect temp.
So, it actually DOES make a significant difference in some cases.
Another example, baking a potato. I have cooked potatoes in the oven without foil, they get done in about an hour. If I wrap them in foil shiny side in, they are done in 45 minutes. If I wrap them in foil shiny side out, they take an hour and a half. The only other difference is the skin gets soft if cooked in foil and gets crispy if cooked w/o foil.
Bottom line, if you're grilling on the bottom rack where the foil is sure to get sooty, then it probably isn't going to make a HUGE difference, but if you're wrapping something in foil and putting it on the top rack, then it will take you twice as long to cook if you put the shiny side towards the heat.
Tropical Buzz
Old 08-11-2008, 09:27 PM
I cached some of my 'stuff' in the hub cap one day, years ago when I passing through Texas. Can't be to careful you know. When I got across state I popped off the hubcap to retrieve it. Much to my dismay the contents had broken open and the 'stuff' went flying when I popped the hub cap off!
I was a good 2 or 3 hours recovering it, one small piece at a time,,, with tweezers. Dang, should have used some tin foil, shiny side out.
Old 08-12-2008, 01:14 AM
Jamo's Avatar
Super Moderator
LMFAO
Jamo
Old 08-12-2008, 05:15 AM
Buzz's Avatar
Oy Ernie - did you get tagged by radar at any time while the stuff was in the hubcap? If not, you might be on to something...
Tropical Buzz
Old 08-12-2008, 09:29 AM
relaxinrob's Avatar
Cobra Make, Engine: FFR Daytona Coupe done to replicate CSX-2299 at the '64 LeMans
I bet it was to hide what he really had in the soda bottle.......Jack Daniels!!
Replicas are the highest form of flattery!
http://www.rehobothproperties.com/coupe.htm
Old 08-12-2008, 01:46 PM
427 S/O's Avatar
Buzz, that was loooooooong before radar, 'canned heat' was number '1'......or close.
Perry
Old 08-15-2008, 01:55 PM
I remember kids on field trips doing this. They would usually wrap a couple of layers of paper towels around the can and then cover it in foil.
Joe Weight
The Ultimate in Aluminum Bodied Replicas
Old 08-15-2008, 02:58 PM
jams's Avatar
Go Joe! I knew someone out there must have heard of this tin foil trick!
