Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Midstates Cobra's---Speak with Bob Kallio
Old 05-14-2005, 09:46 AM
Default Question for you Midstates Guys
Did your cars come with a dash panel, or did you have to make one?
The Shell Valley cars have a fiberglass dash molded into the body.....The pictures of the Midstates cars that I have seen have separate dash panels....is this true?
Old 05-14-2005, 01:12 PM
RON N BKFLD's Avatar
Cobra Make, Engine: KMP241 427 S/C 482 Shelby
BILKINS,,,,
THE MIDSTATES I HAD (1988 MODEL) A VINAL COVERED FIBERGLASS DASH PANAL ATTACHED TO TABS LIKE MANY OTHER BRANDS . MY KIRKHAM DASH IS ATTACHED THE SAME WAY.
RON
RON N BKFLD
Old 05-14-2005, 04:44 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Smile
Yep, Like Ron said. Mine is shaped like an original but it's fiberglass.
Hersh
Old 05-14-2005, 06:34 PM
Is it curled back on the ends.....and how thick is the fiberglass?
Old 05-15-2005, 04:20 AM
Cobra Make, Engine: In Limbo for the time being
Yes, it is curled back on the ends and from what I can remember of the thickness before it was covered ,its about 3/16 thick. Check out the 8th pic in my gallery and you can see the curl on the dash good .
Old 05-15-2005, 04:32 AM
Thanks Chris....I guess it comes blank so you can cut your own holes, right? And how does it mount? Does it bolt to the cowl hoop?
Old 05-15-2005, 04:42 AM
Brent ,
Yes it can come blank so you can drill them how youwould like to, but I had MS drill a classic guage layout for me . It does mount to the cowl hoop there are a few tabs coming off the hoop to bolt it to. Mine are molded into the dash panel so not to see them after it was covered.
Old 05-15-2005, 04:54 AM
Blykins,
What year was your SV produced? I've got a mid-90's production and my dash bolts in. Yours is molded in???
Old 05-15-2005, 04:58 AM
Mine was built in 2003. It's all molded in. No tabs. I would give my right juevo if it would have been the way yours is....
Old 05-15-2005, 09:02 AM
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
brent on the shell valleys i take and cut the dash out leaving 3/4 inch of the fiberglass on the top. I then use thread certs that i install into the fiberglass for re-attachment of an aluminum dash panel that i make, This allows me to work on things much easier, and gives me the option of having the aluminum or covering it in vinyl.
Old 05-15-2005, 09:11 AM
I have an aluminum dash panel covered with vinyl (or will be after I settle things with the upholsterers) and I've done things about how you did it. I cut out most of the fiberglass leaving enough to mount the aluminum too. However my dash panel doesn't curve back at the ends....
Do the ones you make curve back?
Old 05-15-2005, 09:39 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
Here's a pic of the Midstates dash as received. I had Bob tag the dash with the guage locations - he would have drilled them too, but I didn't want that.
I attached it to the 3 tabs on the cowl hoop by drilling and using carriage bolts. When I tightened the nut, it pulled the square portion through the dash and held it from rotating. That way there is very little exposure on the outside of the dash.
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 05-15-2005, 12:49 PM
brent.The one that is in my latest 427 is not, its just flat with a 1'' wide bend from the bending brake at the bottom edge. towards the outside both sides i have it tappered upwords from the bottom.
Old 05-15-2005, 01:48 PM
Yeah, that's the way mine is.
Old 05-17-2007, 08:00 PM
RedSabre's Avatar
Registered User
Mine did not have a dash included and the builder had one made custom. It is 1/4" polished aluminum with some custom milling on it. He did the same for the tunnel console.
Old 05-24-2007, 05:49 PM
Cobra Make, Engine: Shell Valley, 514 SVO ... now a 4.6L with an AOD!
The Shell Valley body did have the dash molded in (except for some of the very first cars). With the new Generation II replica we are currently building, the dash is removable. It sure makes life easier! I do have fiberglass dash panels available, but a lot of guys have used aluminum dashes like what you guys are doing.
Dana
Old 05-24-2007, 06:53 PM
Dana, does the fiberglass dash curl inward at the ends...or is it flat all the way across?
