Go Back   Club Cobra > Club Forums > New England Cobra Enthusiasts
Old 04-23-2004, 02:37 PM
Cobra Make, Engine: Venom 351W
Send a message via AIM to joeg
Angry Carb Leaking
My 7 month old Edlebrok 650 cfm Carb has developed a leak. A small drip of fuel is dripping into the primary chamber from the needle valve adjustment causing the idle to vary from 900-1500rpm. If you look into the carb you can see a small drop of fuel every few seconds leaking.
joeg
Old 04-27-2004, 02:07 PM
REDSC400's Avatar
Send a message via AIM to REDSC400
Joe:
This sounds minor. I am sure the Venom guys can fix this or better yet show you how to fix it. I suspect there is a small washer or gasket at root cause. Maybe a call to Edelbrock could find a quick remedy?
Art in CT
Old 04-27-2004, 02:54 PM
RallySnake's Avatar
Joe,
Be very careful looking down into the carb with the engine running. It's easy to get a faceful of flames. Is your throttle cable allowing the lever to return all the way to the stop?
Paul
