Go Back   Club Cobra > Club Forums > NorCal Cobras
Old 10-22-2009, 09:33 PM
Cobra Make, Engine: SPF 02345, Roush/Yates 358 Sprint Cup motor
I believe the race/street bias ply tires (Billboards & TDs) are supposed to be at about 18-20psi.
Old 10-23-2009, 06:59 PM
dcdoug's Avatar
My tire pressures are the same all around - about 26 psi, which was where the Ford dealer had set them that did the alignment. Will more psi or less psi increase the wandering/darting, or does that not really impact it specifically?
www.partskeeper.com
Old 10-23-2009, 07:52 PM
Doug, as a general rule, the front tires on our cars are going to have a couple of pounds more than the rear. One way you can get a feel for the best pressure is by using a pyrometer to measure the temps on the inside, middle, and outside of your tires. You then adjust the pressure so the middle temp is as close to the other two as possible.
Old 10-23-2009, 08:28 PM
tmareina's Avatar
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
I second JJ Cobra's recommendation...I had Tom Lucas at FE Specialties do my car and the handling was exceptional...on the track as well as the twisty roads in the Sierras (Quincy) where I live. You won't be sorry.
Tom Mareina
Old 10-23-2009, 08:31 PM
Except when he writes the check for the round trip transportation costs to have his car trucked to Sacramento from DC.
Old 10-23-2009, 08:36 PM
tmareina's Avatar
Well Gunner, from Sac, wrote the first thread and that was the one I was referring to. DC came in much later.
Sorry for the confusion.
Tom
Old 10-23-2009, 08:44 PM
Doug's made of money... he darn well might ship is car off to Sacramento for a quick alignment.
Old 10-23-2009, 09:00 PM
Rwillia4's Avatar
Darting around sounds like something in the front end may need tending to (like a tie-rod end)
Originally Posted by CHANMADD View Post
The biggest mistake new Coba drivers make is to thinkthat the car is going to drive like a BmW.
Mine handles just like a BMW
Old 10-23-2009, 09:48 PM
Dennis Olthoff told me to run my TD's at 18psi, it seemed to make the car more compliant than running them at the higher tire pressure.
Also, remember that race tires need to get up to temperature before handling correctly.
Also, the fact that the north east has some pretty rutted out roads doesn't help either.
Old 10-23-2009, 09:55 PM
Gunner's Avatar
Originally Posted by lloyds1 View Post
Dennis Olthoff told me to run my TD's at 18psi...
Man, you'll listen to anyone, won't you?
Old 10-24-2009, 09:02 PM
jperickson2001's Avatar
I went to the 49'er truck stop at West ElCamino ave. and I-80. Fill your gas tank up and then subtract 8lbs. per gallon. You can get it front/rear divided. Cheap. My FFR was 2160lbs - 100 lbs for fuel for 2060lbs. I should have taken all the tools and jack out when I did it also but I didn't.
"What's behind me does not matter"
Old 10-24-2009, 11:02 PM
Rick Parker's Avatar
18lbs is not enough air pressure, the sidewalls will flex too much. Cold should be near 25 in the front and 24 in the rear shooting for as close to 32 & 30 when things get real hot under track usage. Reccomended by Roger Kraus Racing.
18 lbs is too soft for responsive driving even on the street. IMO I base this on my having used Goodyear Blue Streak Sport Car Specials for several years. They are a very similar tire just a different tread.
  #33 (permalink)
Old 10-25-2009, 07:20 AM
"Cobra Make, Engine: FFR1509, 302 EFI, 350hp 1/4 ml 12.20@125mph"
Perickson-how do you get 125mph out of 350 HP?
What Rick said x 2. I've had 4 sets of TD's and one set G'years.
Chas.
  #34 (permalink)
Old 10-25-2009, 12:52 PM
UB DRMNG's Avatar
Cobra Make, Engine: FFR, 302EFI, Supercharged
Depending on the formulation, gas weighs more like 6lb per gal (5.9-6.4). Water is a bit over 8lb per gal. But this will help make up for the tools!
  #35 (permalink)
Old 10-25-2009, 06:09 PM
Now I see how you got a 600hp trap speed...
Chas.
  #36 (permalink)
Old 10-25-2009, 09:55 PM
Sorry about that, 6 lbs is better. It has been a while since I used the formula.
  #37 (permalink)
Old 10-25-2009, 10:08 PM
pgermond's Avatar
Check with the River City Club in Sacramento. A few years back they had a weigh-in at Winston Cup shop here in Roseville off of Foothills Blvd. All four corners with independent scales. Perfect balance setup.
Phil
http://www.uniquecobra.com/
  #38 (permalink)
Old 11-08-2009, 07:49 PM
dcdoug's Avatar
I adjusted the tire pressure today to more like 26-27 in the rear and 28-29 in the front (the pressure is exact in all tires, but I am not sure of the completely cold temp as I drove about 1/2 mile to the gas station before filling them, so they might have been warmed up slightly - will check again when they are cold). Slightly rougher ride, but the car handles much better. I think that was it. I will get the cross weights done at some point on the CACC scales too just to be sure, but it's much better now.
www.partskeeper.com
  #39 (permalink)
Old 11-08-2009, 07:53 PM
Today was a nice day for a ride. I had her out for quite a bit just in case we don't get any more nice weather until I pop her in to the bag later this month (or maybe early December). High 60's is my favorite driving temperature.
  #40 (permalink)
Old 11-08-2009, 08:07 PM
dcdoug's Avatar
One of the nicest days of the year today. I could have driven all afternoon. It's not like the skins are worth watching. What a train wreck. At least they made an effort in the 2nd half so I didn't have to swear off them forever.
www.partskeeper.com
