Go Back   Club Cobra > Club Forums > NorCal Cobras
Old 06-15-2010, 02:16 PM
Bxx1's Avatar
Default Flat tappets ZDDP concerns
http://www.mobiloil.com/USA-English/...ollection.aspx
FYI:
For all you Cobra owners with flat tappets and concerns regarding sufficient zddp/oil. This link was taken directly from Mobil website.
Old 06-15-2010, 02:34 PM
dcdoug's Avatar
Why run this for flat tappets,
http://www.amazon.com/Mobil-94002-Sy.../dp/B000COPC9S
when you can run this at 50% of the price?
http://www.amazon.com/Brad-Penn-Oil-...6634025&sr=1-1
www.partskeeper.com
Old 06-15-2010, 03:27 PM
My engine doesn't like synthetic so that's out. Brad Penn is good stuff but not readily and easily available.
Solution for my flat tappet old school side oiler? Shell Rotella 15-40 and a can (or two because I use 12 quarts of oil per change) of STP. Rotella has the ZDDP as does STP, together it apparently is "enough". Coming up on 10,000 HARD miles with my flat tappet and looking good!
Old 06-15-2010, 03:31 PM
Cobra Make, Engine: 396W Kirkham KMPS036
I get my Brad Penn from the Oil Warehouse, good price.
http://theoilwarehouse.com/?mainURL=...acing_Oil.html
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 06-15-2010, 03:38 PM
dcdoug's Avatar
FYI - If you are an Amazon Prime member and get the free shipping, the price is the same on Amazon. And you get it the day after you order it.
www.partskeeper.com
Old 06-15-2010, 03:57 PM
FWB's Avatar
FWB FWB is offline
the price of the oil isn't bad but 21.00 shipping hurts.
My company, Origin corporation, is in the process of a Brad Penn distributorship. Our location is in PA so the availability will be good. once things are sorted out i will make it known what pricing will be so others here at CC will be able to buy hassle free. we will be starting out with engine oils but would like to become a full line supplier eventually.
thanks, fred
Old 06-15-2010, 04:02 PM
Bob In Ct's Avatar
For those of you wanting a 5w-30 or 10w-30 with higher ZDDP I would recommend Redline (1,200 PPM ZDDP).
Old 06-15-2010, 04:09 PM
55312's Avatar
I've been running Brad Penn for 2 years. Good stuff. Got my local parts store to order it through their distributor. I buy it by the case so the price is fair for what it is.
Tim
Old 06-15-2010, 04:14 PM
dcdoug's Avatar
thanks, fred
Sign me up. Happy to buy from another CC member when you get up and running!
www.partskeeper.com
Old 06-15-2010, 04:22 PM
CobraEd's Avatar
Run whatever your favorite oil is and then add this:
http://www.eastwood.com/zddp-plus-oi...e-4-fl-oz.html
Best of both worlds.
________
________
Old 06-15-2010, 04:24 PM
FWB's Avatar
FWB FWB is offline
i'll keep you up to date..
fred
Old 06-15-2010, 04:30 PM
Bernica's Avatar
Senior CC Premier Member
Or this.....
http://www.cam-shield.com/
Old 06-15-2010, 05:35 PM
jwd's Avatar
jwd jwd is offline
Or use Shell Rotella or Chevron Delo at about $2 a quart and available everywhere.
Old 06-17-2010, 09:01 AM
decooney's Avatar
I've been using Shell Rotella for the past three years on my solid lifter flat tappets
Duane
Old 06-17-2010, 09:30 AM
55312's Avatar
Shell cut back on the P and Zn in Rotella 2 years ago. That's when I switched to Brad Penn.
Tim
Thats when I started using a bottle of STP!
Still, I think the ZDDP content is high enough even in the new Rotella oil.
