06-15-2010, 02:16 PM
Flat tappets ZDDP concerns
http://www.mobiloil.com/USA-English/...ollection.aspx
FYI:
For all you Cobra owners with flat tappets and concerns regarding sufficient zddp/ oil. This link was taken directly from Mobil website.
06-15-2010, 02:34 PM
MD
www.partskeeper.com
06-15-2010, 03:27 PM
My engine doesn't like synthetic so that's out. Brad Penn is good stuff but not readily and easily available.
Solution for my flat tappet old school side oiler? Shell Rotella 15-40 and a can (or two because I use 12 quarts of oil per change) of STP. Rotella has the ZDDP as does STP, together it apparently is "enough". Coming up on 10,000 HARD miles with my flat tappet and looking good!
06-15-2010, 03:31 PM
Cobra Make, Engine: 396W Kirkham KMPS036
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
06-15-2010, 03:38 PM
MD
FYI - If you are an Amazon Prime member and get the free shipping, the price is the same on Amazon. And you get it the day after you order it.
www.partskeeper.com
06-15-2010, 03:57 PM
Originally Posted by Robert McLinden
the price of the oil isn't bad but 21.00 shipping hurts.
My company, Origin corporation, is in the process of a Brad Penn distributorship. Our location is in PA so the availability will be good. once things are sorted out i will make it known what pricing will be so others here at CC will be able to buy hassle free. we will be starting out with engine oils but would like to become a full line supplier eventually.
thanks, fred
06-15-2010, 04:02 PM
For those of you wanting a 5w-30 or 10w-30 with higher ZDDP I would recommend Redline (1,200 PPM ZDDP).
06-15-2010, 04:09 PM
VT
I've been running Brad Penn for 2 years. Good stuff. Got my local parts store to order it through their distributor. I buy it by the case so the price is fair for what it is.
Tim
06-15-2010, 04:14 PM
MD
thanks, fred
Sign me up. Happy to buy from another CC member when you get up and running!
www.partskeeper.com
06-15-2010, 04:22 PM
VA
Run whatever your favorite oil is and then add this:
http://www.eastwood.com/zddp-plus-oi...e-4-fl-oz.html
Best of both worlds.
________
________
06-15-2010, 04:24 PM
i'll keep you up to date..
fred
06-15-2010, 04:30 PM
Senior CC Premier Member
Originally Posted by CobraEd
Or this.....
http://www.cam-shield.com/
06-15-2010, 05:35 PM
Originally Posted by dcdoug
Or use Shell Rotella or Chevron Delo at about $2 a quart and available everywhere.
06-17-2010, 09:01 AM
I've been using Shell Rotella for the past three years on my solid lifter flat tappets
Duane
06-17-2010, 09:30 AM
VT
Shell cut back on the P and Zn in Rotella 2 years ago. That's when I switched to Brad Penn.
Tim
Thats when I started using a bottle of STP!
Still, I think the ZDDP content is high enough even in the new Rotella oil.
