Go Back   Club Cobra > Club Forums > NorCal Cobras
Old 09-23-2010, 11:04 AM
wanab5150's Avatar
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
Default Superformance Alignment Specs
I removed the top and bottom control arms on the right rear of the car recently looking for a nasty noise, lubed everything regardless if it needed it or not, and the noise seems to be gone,. Time will tell.
Additionally, I lowered the car slightly front and rear when I first got it. It was a little tall for the 315x17's and 255x17's, and Goodyear F1's, but it was initially set up with those wheels and tires. The alignment Guru said the fact I lowered it made very little difference in the specs.
Because I disturbed the rear camber and toe in on the right rear, I took it down for a 4 wheel alignment. What I found was surprising although it shouldn't have been.
The front toe in was perfect at 1/8" total toe in, however, the camber was at a full degree negative and should be 1/4 degree negative for street and max of 3/4 degree negative for competition. Castor was 5 degrees positive. I set it to 4 degrees positive.
The rear left was right on at 1/8 deg. and camber at 1/2 degree negative. I set the right side at this same spec.
The car has felt neutral for the 8,000 miles in the last 3 years I've had it, so I set it up in the middle of the specs. Surprisingly, the tires show perfectly even wear even though the specs were set past the competition limit in the front and close to competition specs in the rear. The alignment guy said he has done Cobra's before and tire wear does not seem to be an issue if the specs are even close to what's called for in the manual.
I'm a happy camper. Happy Motoring!
My car is #2769 and the specs below are the ones in the manual I received with the car.
(Front wheels)
Toe IN 1/8" total
Camber 1/4 degree negative. For competition 1/2 to 3/4 degree neg
Castor 2-6 degrees positive
(Rear Wheels)
Toe In 1/8" total. For competition 1/4"
Camber 1/4 degree negative. For competition 1/2 to 3/4 degree negative
Tom
I miss my Tazer
Old 09-23-2010, 03:30 PM
I had a horrible noise from the rear after hours of investigation it turned out to be the sway bar bushings. I lubed with krytox (no hydrocarbons) lubricant and no noise in 2 years. If you use regular grease it will swell the bushings and the noise will return.
Old 09-24-2010, 10:04 AM
wanab5150's Avatar
I'll keep that in mind if it rears it's ugly head again...Where do you find Krytox?
Tom
I miss my Tazer
Old 09-24-2010, 07:25 PM
ROSS WEAVER's Avatar
http://krytox-lubricants.com/
Old 09-25-2010, 04:48 AM
GM used to sell a small tube. They recommended it for weatherstripping and other elastomers.
Old 09-26-2010, 10:52 PM
pooreds's Avatar
Cobra Make, Engine: SPF 2690 427R
Motion Industries is a Krytox distributor, the stuff is real spendy, I wonder which NLGI grade is the best for suspension bushings??
beware of slippery skid stuff..
Old 09-27-2010, 10:09 AM
wanab5150's Avatar
Ed, just so you don't get confused.... an elastomer is not a condom!.
Tom
I miss my Tazer
