Go Back   Club Cobra > Club Forums > NorCal Cobras
Old 02-09-2012, 07:41 PM
Cobra Make, Engine: Superformance #1723-427 Windsor
Default new tranny fluid
How do you add tranny fluid on a tremec 3550.
Old 02-09-2012, 07:48 PM
Cobra Make, Engine: owned Kirkham for 11 years
Mike,
I`m not sure about a3550, but on the tko 600 the fill hole is located on the passenger side of the case about half way up. Take out the square head bolt and fill tran to the hole level
Maurice
Old 02-09-2012, 07:51 PM
Im sure the 3550 is the same i just wondered how you got the fluid in.
Old 02-09-2012, 08:23 PM
im sure the 3550 is the same but i was wondering how you got yhe new fluid in
Old 02-10-2012, 08:30 AM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
buy one of those hand pump kits. screws onto the bottle and pumps the fluid in. made by Sta-lube
- Mel
Old 02-10-2012, 08:58 AM
DonC's Avatar
I picked up a plant sprayer with a hand pump to pressurize it's container (4 qt. capacity) at Home Depot. Removed the screw adjustable nozzle and added about a 2 foot length of 3/8 surgical tubing just pressed over the remaining nozzle on one end with about a 6 inch piece of aluminum fuel line with a 180 degree bend in the other. Total cost about $15.00.
To fill the transmission remove the fill plug, add transmission fluid to the pump bottle, pump up the pressure and hang the curved aluminum fuel tubing in the fill hole. Press down and lock the release lever for the sprayer and just monitor the level of fluid in the sprayer as it goes down. As it gets near where I think it should be I monitor the fill hole and as soon as fluid starts to emerge I shut off the sprayer, wipe the excess off the outside of the transmission and put the fill plug in.
Whole operation takes about 15 minutes. The fluid moves slowly enough so there's very little spillage.
DonC
