Go Back   Club Cobra > Club Forums > North Bay Cobras
Old 12-20-2009, 08:09 AM
Senior ClubCobra Member
Default January Breakfast
This month's breakfast will be January 3rd, 10:00am at the French Garden in Sebastopol.
This is a nice place with plenty of parking.
8050 Bodega Avenue, Sebastopol, CA‎ - (707) 824-2030‎
Contrary to what we discussed at the last breakfast, we'll keep the breakfast the first Sunday of the month for now.
See you there.
Old 12-31-2009, 06:27 AM
SF_SN888KE's Avatar
Cobra Make, Engine: Cutting Edge Replicas, 427 World block SBF, TWM Injection
The weather looks dry (and cold) for the weekend. I plan to make it.
Ron; SF_SN888KE
Cutting Edge Replicas 427
Shell Valley Daytona #27
Old 12-31-2009, 08:39 AM
Great Ron. Sounds like you have things fixed up. Good to hear. See you there.
Also a reminder that everyone is welcome to these breakfasts. Just show up and join us.
Old 12-31-2009, 11:44 AM
SF_SN888KE's Avatar
Paul,
Actually, I'm bringing the Daytona. Got the new side pipes on - a little quiter, and better weld joints.
Cobra fuel pump update: Checked wiring and fuses and etc. I believe it was a bad electric fuel pump. Got a new fuel pump and the fuel pressure is back to 40 psi, but does not hold pressure when turned off ... removed the injectors for check and service (might be crap in the injector filter). Also decided to remove the fuel tank and clean, looked like there was still some junk in the tank. and also fix a fuel sender gasket leak. Will also put in another baffle in the tank to help control fuel slosh and maybe some fuel cell foam. Don't want to have a new fuel pump to ruin it with crap in the tank. The Cobra should be back together for the Feb brunch! Always tinkering ....
Ron; SF_SN888KE
