Go Back   Club Cobra > Club Forums > NW Cobra Club
Old 06-13-2003, 11:43 AM
Cobra Make, Engine: SPF 1249
Default Ininca Shield
This is probably an old thread but do any of you guys have this product installed on your cars? If so where did you have it installed and what was the cost.
Old 06-13-2003, 11:53 AM
speed220mph's Avatar
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Check the following thread. It will lead you to what you want to know.
Click on: http://www.clubcobra.com/forums/show...832#post358832
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
Old 06-13-2003, 01:41 PM
Blue Cobra's Avatar
Cobra Make, Engine: Contemporary Classic 427 S/C, Full Roller 429ci Super Cobra Jet, RHP Flowed BlueT & RHP Cam, CompCarbs, AirGap, V12 E-Type Jaguar F+R, 4SBBTL
Thumbs up Save the Hassle
Save yourself the hassle and go have the real stuff put on. They will warranty against paint chips and glass cracks for 3-years. Yes even the headlights can have it applied.
Stongard is located in Bellevue, and after the time you will spend applying and re-applying your Invinca-sheild a few times, you'll have wished you went here:
http://www.stongard.com/sgcontent/default.asp
They will create custom patterns (and every Cobra replicar is different) to cover almost part of the car you want them to. I just wish they could have covered the entire car with it.
K
Old 06-13-2003, 01:58 PM
Hey Blue: Bet you they both use the same "real" stuff, which is from 3M. As for having Invinca Shield re-applied, don't think you can prove it from the Olthoof's. They use it on many of their SuperFormance cars with great results. Just what I know from this perspective. My guess is they are both good, so whatever rings your chims will work.
Tom
Old 06-16-2003, 08:40 AM
Jake's Avatar
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
Keith, The 3M product works well and was applied to my car from the factory. I think you should just use some clear scotch tape....after all they are just KIT cars.
Jake Greger SPF #390
Old 06-17-2003, 01:02 PM
Zderf's Avatar
Cobra Make, Engine: VICTORY, 92 C.I., belt drive, saddle bags.
Blue Cobra is spot-on.
Stongard
1485 130th Ave NE, Bellevue, WA 98005
Phone: (425) 646-0670
I had my rear fender leading edges done by them (wish I had done the whole car at new). There is no need to remove for cars shows etc, as the material is almost invisible. If it really gets doinked, you take it in have it replaced. I also did my headlamps with another similar material that is a good 0.125" thick to prelcude rock damage.
All Bellevue and Seattle area exotic car dealers use these guys. I saw 2 new Ferrari, 1 new Porsche Carrera Turbo, various MB's, and a host of cars there from Park Place which is just down the street. (I even saw a Z06 that some Cobra guy named Kevin owns with the entire front end covered!!!)
Zderf
Old 06-17-2003, 02:59 PM
Cobra Make, Engine: Superformance '533'
Keith,
I know at least one Superformance guy had big problems with the install quality. Then when they tried to remove the screw up it took patches of paint.
Just my $.02 worth
All I need is a full tank of gas and a clean windshield
Old 06-17-2003, 03:58 PM
Chad:
I know about the Superformance guy you speak about. The paint that came off was under the oil cooler, the area that doesn't get much attention when it comes to prep or painting. All that meant was the Scotchcal stuck and the paint didn't. It was a bit of a scam to get his car painted anyhoo.
Tom
Old 07-02-2003, 03:17 PM
Blue Cobra's Avatar
Default StonGard
They removed a patch of the stuff from my Zee-Oh-Six and replaced it without an issue to the paint. This treatment barely uses any sticky stuff, just lots of static and suction. Must have been the paint on the Superformance that was the issue.
I've got the Cobra appointment for July 14th at StonGard to have it done too. Just had the rock chips fixed and don't want to do that again! Last night I tried to put on wire stone guards over my headlights and what a joke! Gonna return them to Finishline and have the headlights covered too by StonGard plastic while it's in their shop.
Hope to see you all on the Glacier ride!
Kevin
