Go Back   Club Cobra > Club Forums > NW Cobra Club
Old 08-30-2009, 09:36 AM
UrQ's Avatar
UrQ UrQ is offline
Cobra Make, Engine: FFR
Default Recomendations for garage floor painting
Any recomendations for reasonable painting of new garage floor in the Seattle/Kirkland area?
Old 08-30-2009, 07:16 PM
Jake's Avatar
Cobra Make, Engine: Superformance Cobra #1628, Coast Performance Stroker 427W Ford 520HP/535FT.TQ, Blue with white stripes
I would try Costco. They have a nice product that they install.
Jake
If your going to dream, dream big!
Old 08-30-2009, 09:04 PM
MaSnaka's Avatar
I used a 2 part epoxy. Polyamide Epoxy????I believe its called. The same stuff used to paint swimming pools. Industrial strength and quite durable. The fumes will kill you so use good ventilation and respitator. Tints to any color but can be slippery when wet or covered in fine sawdust. I recomend using some form of a texture additive. You can see pics of my floor in my gallery. If you need more info let me know.
Old 08-30-2009, 09:35 PM
Cobra Make, Engine: ffr-347
I used the u-coat-it system on my new shop-BIG mistake-prepped the floor as they recommended-now got peeling-have a claim against the company-next for me is to tile over once the car is built.
Old 08-31-2009, 07:14 AM
JTD JTD is offline
Cobra Make, Engine: SPF
Default Floor
http://www.armorpoxy.com/
Old 08-31-2009, 07:19 AM
Cobra Make, Engine: Superformance SP02228, ROUSH 402R w/custom DiVinci Performance Carb.
I used the RustOleum Epoxy Shield kit I bought at Lowes. I think i paid $60 for each kit (used 2 kits) Three years now and not a single problem with it.
http://rustoleum.com/CBGProduct.asp?pid=16
Old 08-31-2009, 07:45 AM
Cobra Make, Engine: SPF#1245 w/ 1966 427 SO
There are several good epoxy garage floor paints out there. Home Depot and Lowes both have decent kits, Sherwin Williams and Benjamin Moore do, and so does Griot's garage. Many kits have the colored granules that you can sprinkle on to give it that "granite" look, and you can go over it with a clear coat as well.
However, and I can't stress this enough, a good garage floor paint means nothing unless you do the proper prep work.
It is my opinion that you MUST etch the concrete with muriatic acid in order to allow the epoxy to bond to the floor properly. I know some kits say that you don't need to, but take some time and do it anyway. I've painted several garage floors in my day and I've NEVER had one peel.
-Take your time and do it right. You won't be sorry.
Old 08-31-2009, 08:11 AM
Don Don is offline
There are a number of Threads on the subject, 2 of which are:
Garage floor options
Garage Floor Paint Recomendations
I used garage floor paint as the search term
Two items for consideration:
* Moisture in the cement floor. A very basic method is to tape on all sides an approx 1 ft sq of plastic to the floor and see if condensation appears after leaving overnight. . May not be the final determination, but an indication. You mentioned the floor is new. A professional vendor would not apply the product due to the moisture content of the cement.
* Floor prep is of utmost importance, the best of products will not adhere if the surface is nor properly prepared.
Old 09-01-2009, 03:19 PM
UrQ's Avatar
UrQ UrQ is offline
Originally Posted by Don View Post
You mentioned the floor is new. A professional vendor would not apply the product due to the moisture content of the cement..
By new I mean has not been driven on, house was built at the start of this year so it's been down for about 6 months
