Go Back   Club Cobra > Club Forums > Ohio Cobra Club
Old 02-27-2006, 08:11 AM
rdorman's Avatar
Renegade Nuns on Wheels
Default LCS '06 Raffle Car
Win a finished 427 Cobra replica! Only 2500 to be sold. Drawing is June 24, 2006. Need not be present to win. All the details and tickets are available on www.londoncobrashow.com
This will be a fully optioned out, ready to go, finished car. Painted solid red.
Here is a list of sponsors and specifications!
Raffle car related items:
Provided by Shell Valley Companies Inc. http://www.shellvalley.com/
Fiberglass 427 body, all seam lines filled and sanded, and has black primer coat, only finish and block sanding required before painting
· Cockpit, trunk compartment, and inner fenders bonded in place
· Underside and wheel wells painted gloss black
· Hood and trunk hinges installed on body
· Transmission tunnel reinforced with steel plate
· Dash panel molded into body
· Stress points reinforced with Kevlar
· Rectangular tube frame with all suspension mounts included
· Frame painted gloss black enamel
· Motor mount bracket of your choice welded in place
· Transmission mount, universal type, included
· Cowl hoop with door hinges included
· Body mounted to frame
· Body mounting kit and weatherstrip included
· Tubular upper and lower A frames
· New spindles
· Strut rod eliminator package (strut rod package available)
· New rack and pinion complete with bushings and tie rod ends
· New 5 bolt rotors 11" diameter
· All bearings, seals, and dust caps
· Rebuilt brake calipers complete with caliper brackets
· Polished aluminum coil over shocks, adjustable, with springs
· Front brake hoses with fluid bolts and washers
· 4 Link polished aluminum radius arms
· Narrowed 9" Ford rear end with new axles (bearings and seals not included) and all brackets welded on, 3rd member in used condition (rebuilt 3rd member optional)
· New 5 bolt rotors, 11" diameter
· Disc brake package includes rebuilt brake calipers complete with hand brake hardware, caliper mounting brackets included
· Rear brake hoses with fluid bolts and washers
· Rear brake hose with splitter block
· Headers for your application (any big or small block Ford or Chevy)
· Reproduction side pipes (for chrome add $315)
· Computer formed stainless steel brake line kit
· 3/8" aluminum fuel line kit
· Doors, hood, and trunk installed on body
· Complete light package
· Grille mesh screen
· Reproduction side mirror
· Reproduction dash mirror
· Fiberglass glove box compartment
· Hardwood glove box door complete with hardware
· Horn and horn button
· Tinted sun visors
· Clear wind wings
· Reproduction seats, black vinyl (leather available)
· Fitted door panels, black vinyl (leather available)
· Adjustable seat track on driver's side seat
· Complete carpet kit for interior and trunk, black
· Chromed front and rear oval bumpers
· Stainless steel side vent louvers installed in body
· Single roll bar, chrome, complete with mounting kit (double wide available)
· Battery cables, terminals, and battery tray
· Hood and trunk props
· Complete gauge kit (several options available)
· Aluminum radiator overflow tank
· Polished aluminum steering column assembly, complete with lower sector and U-joints
· Heavy gauge steel gas tank assembly, unwelded (welded and aluminum tanks available)
· Reproduction LeMans style gas cap assembly with fill hose
· Gas pedal assembly complete with linkage
· Brake pedal assembly with 2 master cylinders and balance bar (clutch pedal option available)
· Complete windshield assembly, chrome plated brass and 2 surround plates
· New aluminum radiator complete with mounting brackets
· Wiring harness complete with prewired switches
· Complete windshield wiper assembly with new motor, posts, arms and blades
· All handles and latches for doors, hood, and trunk
· Polished stainless steel bumper over riders complete with mounting kit
· Complete emergency handbrake assembly
· 16" high efficiency electric fan
· 15" wood ring, 3 spoke steering wheel
Provided by Keith Craft Inc. http://www.keithcraft.com/
445 cubic inch Big Block Ford FE with 552 horsepower, 570 foot-pounds of torque.
1964 Model 390 Block, .030 over
Fel Pro BS 30138 Rear Main Seal
ARP Main Studs
Scat 4.250 Cast Steel Crankshaft
Scat I-Beam 6.700 Rods
JE pistons
Manley Wrist Pins .990x2.930
Federal Mogul Main & Rod Bearings
Mahle Ring Set
Ultra Dyne flat tappet Camshaft
Comp Cams Flat tappet lifters
Stock front cover
Ford Racing timing set
Melling oil pump
Ford Racing oil pump drive
Stock pointer
Ford Racing eccentric
Stock Oil Filter mount
Canton Pan, dipstick & pick up tube
Professional Products damper
Stock retaining plate
Edelbrock water pump
Edelbrock RPM 6005 Stage II cylinder heads
ARP head bolt kit
Comp Cams Rockers
Edelbrock Intake 7105
Stock thermostat housing
Ford racing head gaskets
Felpro & corteco gaskets
MSD distributor & wires
Pro system 750 double pumper hp
Provided by David Kee Toploaders Inc. http://www.4speedtoploaders.com/
New big spline wide ratio ALLUMINUM CASED Toploader four speed transmission and Hurst shifter. 9” Ford locker third member.
Provided by USAComp, Motorsports Specialties. WWW.USACOMP.COM
Three piece modular Compomotive HB 5 15” rims
Provided by the Finish Line Inc. http://www.cobraaccessories.com/
Visors, Wind Wings, Seat Tracks, Glove Box, Mirrors and Overriders
Provided by Aesthetic Finishers. http://www.afipowder.com/
All Armor Coat high temperature ceramic coating and all Powder Coating
Provided by Cobra Heat. http://www.cobraheat.com/home.html
WarmSeats Carbon Fiber Seat Heaters.
Provided by Rich’s Classic Transport. http://www.richsclassictransport.com/home.html
Shipping to the winner in the continental United States.
Provided by Windy City Cobra Club. http://www.windycitycobras.com/
Big Letter Goodyears tires, vintage style and size.
Provided by Advanced Auto Parts. http://www.advanceautoparts.com/
All misc. parts including MSD box, hoses, wiring supplies, all fluids, etc.
Provided by Lakewood Industries, a Mr. Gasket Company. http://go.mrgasket.com/default.aspx?BrandID=5
Blow-proof bellhousing and block plate.
Provided by McLeod Industries. http://www.mcleodind.com/
Complete aluminum flywheel and hydraulic clutch set up.
Performance Unlimited’s Cobra Valley. http://performanceunlimited.com/cobr...mberdecal.html
Full set of roundelles, meatballs.
California Car Cover Co. http://www.calcarcover.com
Cobra car cover.
Kirkham Motorsports. http://www.kirkhammotorsports.com/m/
Pullies, brackets, oil mounts, etc.
March Performance. http://www.marchperf.com/
Pullies.
Ed Bryant Collision – painting
Dyer Straits – Assembly and finishing
Non raffle car related sponsors:
Cobra Powersports. http://www.cobrasales.com/303r42.htm
303R special edition #42 TGB Scooter.
Snap-On tools. http://www.snapon.com/
Tools, tool box, roll around jack and jack stands
Beaumont Metal Works LTD. http://www.beaumontmetalworks.com/track.html
Very cool track stands
OhioCobraClub.com
LondonCobraShow.com
Old 02-27-2006, 05:33 PM
Godzila's Avatar
Cobra Make, Engine: SPF#1981/ 418Stroker
I got my tickets, wifeys got hers, whatsamatta you guys get yours......................now!
Big Dogs don't bark,,,they just growl real low!
Click to Win a Cobra!!
Old 02-28-2006, 05:04 AM
WV66AC's Avatar
Cobra Make, Engine: Late 70s Allied Industries?? 454 BBC; alum copo heads and intake THM 400 12 bolt posi ++ 06 CL 55 AMG
Sent another check yesterday. Don't tell the boss. Hope springs yet eternal.
Old 02-28-2006, 05:57 AM
rdorman's Avatar
I have to get off my duff while the getting is good! Once the Snap-On dealers get their hands on them, signs go up in the Advanced Auto Parts stores, magazine coverage comes out and we get the raffle linked on a couple of more sites I don't expect them to last! Fortuniately, I know where to get them!
OhioCobraClub.com
LondonCobraShow.com
Old 02-28-2006, 08:08 AM
rdorman's Avatar
I just bought my two tickets!! Ticket numbers 0001 and 0002
No need to send them to me, I already have them!
OhioCobraClub.com
LondonCobraShow.com
Old 02-28-2006, 08:13 AM
mrmustang's Avatar
Gold Star Contributor
Mine are marked 308,309,310 . Remember that when you read them outloud at the drawing
Bill S.
Old 02-28-2006, 08:17 AM
rdorman's Avatar
308, 308, 308, 308.... got it!
OhioCobraClub.com
LondonCobraShow.com
Old 03-01-2006, 09:47 PM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
Talking
Bill S.
There better not be THREE Red Cobras all won by "mrmustang"! He's not a Chicago politician, is he!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 03-01-2006, 09:54 PM
HI Cobra's Avatar
Not to worry - it will go to either 75 or 76.
Flip
Old 03-02-2006, 05:03 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Not at all, I have the winning ticket.
I got it from a VooDoo vender who knows the guy who machined the bolts on the left axle stud on thursday before the full moon of the third month after the summer soltic for the rear end of the truck that delivered the exhaust pipes to the factory.
SO, you can see you all don't have a chance as I got it on good authority.
Old 03-02-2006, 07:19 AM
Godzila's Avatar
[quote][/I got it from a VooDoo vender who knows the guy who machined the bolts on the left axle stud on thursday before the full moon of the third month after the summer soltic for the rear end of the truck that delivered the exhaust pipes to the factory.
QUOTE]
Ha! so you bought your tickets from Dorman!
Old 03-02-2006, 07:20 AM
rdorman's Avatar
[quote=Godzila]
QUOTE]
Actually, Frink is the machinist!
OhioCobraClub.com
LondonCobraShow.com
Old 03-02-2006, 07:32 PM
65LA's Avatar
Excuse me...I really believe ya'll should step aside...allow this one to go to someone that doesn't already own a COBRA..you understand the concept of let others that haven't been...be bitten??? Besides..red is one of my colors...--BUT I see color choice is an option -- so just start painting it white..
Old 03-03-2006, 03:24 AM
BUCKEYE COBRA's Avatar
Cobra Make, Engine: Backdraft #20 302 T5
Two Cobras in my garage would be OK with me!!!!
Old 03-03-2006, 05:34 AM
rdorman's Avatar
How many tickets are you going to buy? Kind of like the lottery, can't win if you don't pay! I would be kind of cool for a new person to get the car
OhioCobraClub.com
LondonCobraShow.com
Old 03-03-2006, 05:52 AM
65LA's Avatar
I placed my order already -- I would love to shake things up here in Minneapolis!
Old 03-03-2006, 05:55 AM
rdorman's Avatar
Minneapolis! I wonder if those big letter goodyear tires can be studded! Ice racing any one
OhioCobraClub.com
LondonCobraShow.com
Old 03-03-2006, 05:59 AM
65LA's Avatar
Don't laugh -- the people here do crazy things like that! Every year there are bets on how many cars go out on the ice -- and don't make it back.. because they fell through.
Old 03-03-2006, 06:02 AM
trularin's Avatar
Member of the north
I got them from Frank after consulting the VooDoo vender and used car salesman.
Of course, since I will be winning the car, I will claim to have gotten the ticket from Rick.
Old 03-03-2006, 07:09 AM
Default Build Updates!!!
The pre-paint assembly is complete!!
The car has been dis-assembled and is on the way to the paint shop where several club members will oversee every detail from fitting and prepping...to the final rub out! In the meantime...many of the components are being plated, powder coated or anodized.
Did you guys take a closer look at this Big Honking K-Craft Motor!!!! I saw it a few weeks ago in person for the first time. Good Gosh!!! it is a beautiful BEAST!! I was amazed with the extent of high quality components used....right down to the finest detail. Just look at the hand crafted Tig-welded, aluminum Valve covers for example. Works of ART!!!
Yes sir!!! I was impressed! But wait...there's more! The aluminum top loader, Big Lettered GoodYears, Free Delivery...even heated seats!...the list goes on...!
Some body is going to be very happy on June 25th!
Buy tickets..or see more details about the car: www.londoncobrashow.com
