February 2026
Old 02-16-2010, 07:20 AM
Default Avaid oil pan connections
Need some help here with my Avaid oil pan.
I have 2 holes in the front, one being the drain on the right and another that is plugged on the left. I also have 2 stems on the front passenger side.
What are all of these for?
Is the other front threaded hole for the Lucas mechanical temp sensor or am I supposed to run that somewhere else? If so where?
I think the larger stem on the left is for the oil vapor canister feedback used on the SC cars???
Help me out
Old 02-16-2010, 07:38 AM
I used the hole on the bottom right ( driver side ) of the pan for my oil temp. sensor and the one on the left for the oil drain plug . The two stems on the pass. side are for the oil dipstick tube connection and , I believe the other is for what you think it is .... oil vapor canister drainback . That`s also the way ERA sets things up on their turn key cars .
Old 02-21-2010, 09:48 PM
PANAVIA's Avatar
BTW: Anyone have a good source for the Aviaid (aviaid 55410) Pans and Pickups , my usual source is having difficulty obtaining them.
Old 02-21-2010, 10:29 PM
Call them directly. I did.
Old 02-21-2010, 11:22 PM
mickmate's Avatar
Hey Dan, you're close drain and temp sender are on front. Temp sender usually pass side I think. The two stems are 3/4" to the puke and 3/8" is the dipstick as the hole in the block for the dipstick runs it into the baffles.
mickmate
http://www.actoncustom.com/
Old 02-22-2010, 05:45 AM
So I should have 2 oil dip sticks?
Old 02-22-2010, 06:02 AM
lovehamr's Avatar
Stolen Avitar
No, he means that if you are running the Aviad pan you canNOT run the dipstick in the block as it would dirrect the dipstick into the Aviad's baffles. This means that the block hole would have to be sealed.
Steve
Old 02-22-2010, 07:46 AM
Originally Posted by lovehamr View Post
No, he means that if you are running the Aviad pan you canNOT run the dipstick in the block as it would dirrect the dipstick into the Aviad's baffles. This means that the block hole would have to be sealed. Steve
And its fun when you figure out that you need to seal that hole after all your machine work is done, the engine is painted and ready for final assembly. So what we did was turn the block on the engine stand so that the hole was facing the floor and slowly ran a tap into the hole, being sure all the tailings came out onto the floor. We then used an allen-head threaded pipe plug to seal it off.
Old 02-22-2010, 07:10 PM
Steve
OH CRAP!!!!!
The engine is assembled, painted, went to dyno, and has a dip stick tube in the block.
Oh this will be fun.
I wonder if I can leave that tube in and just cap it off at the top?
Old 02-22-2010, 07:20 PM
mickmate's Avatar
Dan there's a small frost plug I think it's 3/8 that will just tap in from the outside with a little goop on it.
mickmate
Old 02-23-2010, 08:55 AM
Nick
Can you help me in finding this plug? Thanks
Dan
Old 02-23-2010, 03:44 PM
mickmate's Avatar
These are cute but not what I was talking about http://www.mcmaster.com/#24675k88/=5y4jmb
mickmate
Old 02-23-2010, 04:30 PM
Just pack some RTV in there, It'll be fine.
