03-09-2010, 04:23 AM
mi
Picture request for Lucas firewall components...
Can you guys help me out and post some good close up pictures of the Lucas relays/fuse boxes that were mounted on the drivers side firewall on the origional 427's please.
I am trying to replicate the look and need to see how the wires run as well as location of each piece in retrospect to each other.
I know the wiring differs form car to car depending on what options were installed, I am more interested in how the wiring was run as opposed to what was connected.
03-09-2010, 05:28 AM
HH
Cobra Make, Engine: Alum 427 S/C with KC FE 482 Shelby
Does this help? Should be CSX 3357........
Carsten
03-09-2010, 07:41 AM
mi
Carsten
Not really. I need a close up of the components on the firewall, not on the footbox, and where the wires run through the firewall.
Thanks for posting though
03-09-2010, 07:46 AM
HH
Is this one better? Sorry - those are the only ones I have....
regards
Carsten
03-09-2010, 07:55 AM
Both pictures are CSX3021
03-09-2010, 08:12 AM
mi
regards
Carsten
Yes, that does help. It also shows the oil vapor canister hose to the rear/trans!
Still could use a few showing the right side, anyone?
03-09-2010, 08:29 AM
HH
uuuups - appearently I have a tendency to mix up the chassis numbers of the cars in my garage
May well be that I saved the picture with wrong file name - so thanks to Computerworks I can now have this corrected
thanks for the clarification
Carsten
03-10-2010, 08:44 AM
mi
Any more pics out there?
03-10-2010, 09:19 AM
Senior CC Premier Member
FWIW, here are some shots of my firewall. All Lucas, should be close.
03-11-2010, 07:07 AM
OH
Cobra Make, Engine: CSX4158, alloy body. The Watersnake!
I second that...
4158 has the same arrangement as bernica's...unfortunately the parts guys at Shelby don't have a clue what the pieces are. (not kidding) Apparently newer continuation cars have all modern bits.
Is there an alternate source for these lucas pieces?
03-11-2010, 07:10 AM
OH
Answered my own question. Fuseboxes on ours are Lucas 4Fj and 7fj, as illustrated here
http://www.tvrna.com/lucas/lucas-fuse-boxes.htm
Moss motors carries some lucas bits like the 7fj, still searching for others.
03-11-2010, 07:28 AM
OH
found it...if you decide to go with the continuation style firewall components, PM me. I can source it for you.
03-11-2010, 09:24 AM
Cobra Restorers has many of the firewall electrical components.
www.cobrarestorers.com
I can identify any of the particular parts if you have questions.
03-11-2010, 09:36 AM
BPNorthwest.com has Lucas covers ( TR 6 ? ) for $4.31/cover and Cobra Restorers wants over $12/cover . Don`t know if they are the same , but they sure look the same .... and are both by Lucas .
03-11-2010, 11:23 AM
mi
You can get them cheaper if you watch EBAY. That's what I did
03-11-2010, 04:53 PM
NV
Cobra Make, Engine: 427 SC
British Wiring has everything and decent pricing
http://www.britishwiring.com/
03-14-2010, 06:00 AM
mi
critiques please
What do you think guys,
Am I missing something way off? Still not 100% complete. Stilll have to add gromets on heater hoses, other rod end/heim joint buy driver side foot box for linkage, and final routing/taping of wiring, but I think you get the idea. Heater hoses could have been higher, but they were starting to kink if I went any higher
Ideas/comments appreciated.
03-14-2010, 06:03 AM
mi
more pics
Forgot to mention
This is a FFR chassis, but that footbox does give it away and limited me a LOT!
03-14-2010, 06:32 AM
IL
I really like what you have done. I am after the same thing. Can you post the parts list and the source? That would be a huge help to me.
High Maintenance Racing Team
Run & Gun 2003 - 2013
03-14-2010, 08:41 AM
mi
EBAY! I got everything on ebay from different sellers. The big Lucas DB10 was the hardest to find. They usually go for around $100 to $140.
You can get new ones with modern internals. Someone sent me a like on one of my other threads. Do a search, I am sure you will find it all.
Let me know if you can't find it and I will do some digging.
Dan
