06-17-2011, 07:21 PM
Dan,
On the 289 Stewart Warner 5-smaller gauges, what typically came on the car? I have seen oil temp, oil pressure, water temp, current, and fuel. Is this correct?
___________
06-17-2011, 08:44 PM
VT
Cobra Make, Engine: Factory Five - the 1st Mk4
From Original AC Ace and Cobra by Rinsey Mills, 1990
"Apart from the first one or two cars which used 2.6 Ace 5" main instruments, both the speedometer and rev counter were of 4" diameter, the former being calibrated to 160mph and the latter to 10,000rpm. These dials were manufactured by Smiths, as were all the gauges fitted to cars with COB and COX chassis numbers and US specification cars CSX 2000 to 2200. The exceptions were quite a number of CSX cars fitted with a Rotunda revolution counter manufactured by Faria. From chassis number CSX 2201, US cars were fitted with Stewart Warner gauges as a matter of course, but some earlier CSX cars may have had the Smiths equipment replaced by Stewart Warner items at the Shelby factory (or vise versa by American owner who preferred Smiths instruments)."
So as you can see it can get a bit confusing when you see a CSX car and it has xxx gauges.
Dan,
This is also interesting about the clock on the Stewart Warner gauged cars.
"The lower gauge was an electric clock, which was normally by Smiths but a number of the cars with Stewart Warner equipment used a totally inappropriate clock from the 1962 Ford Galaxie."
"Above the clock were the petrol gauge (left) and the oil pressure gauge (right), reading to 100psi. Above these, from the left, were the ammeter, oil temperature and water temperature gauges."
Short answer to your question: Yes!
George
1975 Porsche 911 Targa Carrera - sold
1952 MG-TD - sold
1962 MGA - sold
Purchased Factory Five Mk4-#1 March, 2010, under construction
06-18-2011, 03:51 AM
Originally Posted by PDUB
Dan,
Correct. Decades ago it was common to find the clock owner replaced with some other gauge. Fuel pressure gauges were common. The one situation that always made me smile was when I came across an altimeter in the clock position.
When examining any Cobra/427 Cobra/AC 289 Sports bear in mind that these are some of the most bashed and modified cars off all time by their owners. A box stock Cobra/427 Cobra/AC 289 Sports is about as common percentage wise as a virgin 1932 Ford roadster.
Dan Case
06-18-2011, 04:01 AM
Dan,
[i]"The lower gauge was an electric clock, which was normally by Smiths but a number of the cars with Stewart Warner equipment used a totally inappropriate clock from the 1962 Ford Galaxie."
I have a copy of that book. I have copies of the more significant books. In this case the author states an opinion "totally inappropriate clock from the 1962 Ford Galaxie" and not a fact. Such positions are opinions. One of my opinions is that it was inappropriate for AC Cars to paint a new Cobra any shade of green as I don't care for any finish on any car that is green. That is just an opinion though.
Dan Case
06-18-2011, 08:36 AM
VT
Yes, he is stating an opinion.
That sentence, however, is hard for me to understand. Is Rinsey trying to say that some of the cars supplied with the Stewart Warner gauges were also supplied with Smiths clocks instead of the Ford clocks?
George
1952 MG-TD - sold
1962 MGA - sold
06-18-2011, 10:13 AM
Cobra Make, Engine: CSX2321
No, I believe he was trying to describe the fact that the cars prior to CSX2201 had gauges supplied by AC that were all Smiths. When the change was made to SW gauges it included a Ford clock.
06-20-2011, 08:30 PM
Thanks guys!
06-21-2011, 04:01 AM
Cobra Make, Engine: AC cox 2699 roadster Riverside FIA RSR2001
Fia
I`ve yet to see or read a reference stating that the FIA`s had a 2 1/16 ammeter. All Fia`s had S.W. 2 5/8 with 3 3/8 speedo Tachs varied both in size and make. If that was because of availability problems or drivers choice I`m not sure?
Ross
06-21-2011, 06:09 AM
clocks
My interpretation of Rinseys "inappropiate" is that if SW gauges fitted then an SW clock should be part of the package. Not a Mix & match. ie Smiths set included a Smiths clock
Ross
07-22-2011, 08:42 PM
As a former owner of CSX2201 (back in the late 60's) I can verify that the car always had SW gauges.
Bill
07-23-2011, 12:47 AM
SA
Smiths clock
Anybody know what clock was fitted on the 289 cars with Smiths gages?
The bezel seems to scale at about 60mm or 2 3/8" OD. Is a Smiths clock in this size available?
Glen
07-23-2011, 06:18 AM
Cobra Make, Engine: ERA 781, 69' 428CJ, PPG BLACK. ERA 3005 Arctic White 331 SBF
On a lot of the original 289's (Slab Sides) it was a clock from a 1962 Ford Galaxie. Some used Smiths, but I'm looking for one now to keep a built original.
We make 3 bad decisions a day. Choose them wisely.
07-24-2011, 07:13 PM
SA
Smiths clock ID?
The clock in this picture is a Smiths, I think.
It scales out at larger than a standard 2" gage.
Any ideas where these came from?
Glen
Reason: change url address for pic
07-24-2011, 10:44 PM
Not 100% sure Glen but I think that's a Smiths clock from a Sunbeam.
60mm face I think. That would make it Smiths model CE.2194/08. (I've been doing a little clock research)
My guess is that clock replaced the original Smiths clock at some point in the cars life. Also note the Lucas switches. Is that a COX car?
Alba gu brąth
07-25-2011, 03:14 AM
SA
Thanks for that Larry. 60mm bezel was my estimate, but haven't seen them anywhere. Do you know where the best place is to look?
The car is an early CSX. Bottom left corner of the pic is ol' Shel's knee.
Glen
07-25-2011, 03:21 AM
SA
Duplicated post, don't know how...
Reason: Duplicated post, don't know how...
07-25-2011, 07:01 AM
Hey Glen
This morning, I was looking at some dash pics I have of 2142 and there's the same clock! Now I'm thinking some Cobra's used the same clock as some Sunbeams.
More research!
Alba gu brąth
07-25-2011, 04:02 PM
SA
Larry - here's a pic of another early Cobra, with the same Smiths clock. So it's not only Sunbeam, but also other Rootes Group cars - Hillman, Humber, Singer and no doubt some others too - that used this clock, so it shouldn't be too hard for me to find a good one. Thanks for your information!
Glen
Reason: update url
07-25-2011, 10:22 PM
Nice job Glen! Yeah, finding one shouldn't be too hard. That part number in my previous post is correct, so maybe a search with that may yield something. Let me know what you find.
Alba gu brąth
