Old 12-29-2011, 07:59 AM
Default Cobra stripe dimentions
Building F5 Mk 4 ---where can I fine the original dimentions
for the racing stripes on 66 SC---
Roy Pinner
Roypinner@gmail.com
Old 12-29-2011, 08:21 AM
LMH's Avatar
LMH LMH is offline
Painting Stripes, FFR FAQ
HTH,
Alba gu brąth
Old 12-29-2011, 08:40 AM
Wbulk's Avatar
Cobra Make, Engine: 66 Cobra
I read everything I could on this subject and found three so called correct stripe measurements. But I also read they did not come with stripes from the factory. The dealers painted them on. ERA had two measurements on their website. One with a 3/4" gap in the middle, the other with 1". For tapered stripes they seem to be wider by 1 1/4"-1 1/2" at the cowel edge of the dash than the nose. The rear deck is the same as the dash and then tapers a little less 1 1/4" below the trunk.
After talking to local club members it seems the popular approach is to make the two nose stripes just wide enough so the outside edge is just outside the oil cooler opening with the main stripes. They look pretty good that way and are easier to tape. On my car that is just about 14 1/2". Then I will taper wider towards the dash. So 6 3/4" X 2 + 1= 14 1/2" at the nose and about 17 1/2" at the dash edge, that's what I am doing.
On the other hand make them how you want!
Wayne
Old 12-29-2011, 11:47 AM
MFE III's Avatar
Cobra Make, Engine: Hurricane Motorsports, 427w
Here's what I used.
http://www.erareplicas.com/427man/stripes/stripes.pdf
Matt
Hurricane Motorsports #1053; 427w
Old 12-30-2011, 12:58 PM
Muldoon's Avatar
Cobra Make, Engine: Excal. AC Cobra, 302, 2-4bbl carbs
Default Stripes
What I used was 8" wide stripes with 1" gap. 3/4" gap, did not seem to have the definition in the separation of the stripes needed.
I looked at other cobras before I did mine, and that seemed to be the consensus.
Mul
Old 12-30-2011, 02:22 PM
Default Roy Pinner
Thanks for the help.
Roy Pinner
Old 12-31-2011, 09:53 PM
Send a message via AIM to krausewich
Hi Roy,
Here is something that I picked up along w/ the ERA info you have.
Hope it helps... I used to pinstripe these with 1/8" on the inside and 1/4"
on the outside, to really set them off ! !
http://www.clubcobra.com/photopost/u...pepattern2.jpg
Mike.
-J. James
M. Krause
1.508.944.3368
Old 12-31-2011, 09:57 PM
Neutral
Default Stripe Dims...
duplicate post...
-J. James
M. Krause
1.508.944.3368
Old 01-01-2012, 06:41 AM
Thanks for all the help---will post picture
when complete.
Roy Pinner
Old 01-01-2012, 07:00 AM
1ntCobra's Avatar
Abnormal CC Member
Originally Posted by Wbulk View Post
... But I also read they did not come with stripes from the factory ...
There were plenty of Shelby American Factory cars with stripes (like FIA, USRRC and Daytona Coupe). CSX3002 is a 427 with stripes that Ken Miles drove a few times.
Old 01-01-2012, 10:08 AM
cobra 53's Avatar
Cobra Make, Engine: NAF 289 Blue/White strips
Can someone explain the history of this broad stripe dimension? Measures? On wath cars applicatet?
Old 01-02-2012, 12:51 AM
cobra 53's Avatar
CSX 2473 is the "winningest" Cobra in History.
