Like Tree12Likes
Old 02-25-2017, 03:51 PM
Dan Case's Avatar
Original Shelby Owner
Ford transmissions are always natural when new, they did not paint them. And "Ford Blue" was not introduced until 1966 model year production.
+1 on being bare but depending one year and model all kinds of paint color marks plus an engineering number stenciled on. In one of Colin's books (think it is one of his) is a picture of a very early HP289 dressed to go into a new Cobra at SAI with transmission attached and on the side of the iron cased Galaxie transmission is stenciled a large number.
Dan Case
Old 02-25-2017, 08:10 PM
CompClassics's Avatar
I am not so certain a "M" gear set would have been available in a 1962 Cobra. "M" gearsets were developed later and became the standard gear set for GT350 Mustangs in both the aluminum (early) case and iron (late) case T10 transmissions.
As per the steciling, I have only seen int on the iron case transmissions, maybe I missed it somewhere? I have seen C3AE and some letter. stenciled on iron transmissions.
Old 02-26-2017, 06:14 AM
Dan Case's Avatar
1+ Iron case Ford production T10s in Cobras had color codes and stenciled numbers. The aluminum T10 cases were complete bare.
Dan Case
Old 02-28-2017, 12:57 AM
peterpjb's Avatar
for my clarification, toploader were never installed in 289 Cobras in the first place?
does that also mean they are not FIA legal?
and are T10 with iron case FIA legal?
Old 02-28-2017, 05:09 AM
1795's Avatar
How would you compare the T10 to the Toploader regarding performance and longevity? From my understanding there are very few T10's out there and that they are rather expensive.
Old 02-28-2017, 07:43 AM
Dan Case's Avatar
What is shown in the FIA 1964 reconfirmation, a confirming of the 1963 documents apparently, is pictures of an aluminum cased T-10 and in the text "Borg-Warner" as the brand with L and K Borg-Warner gear ratios itemized.
All I know of is up to that last street cars and works racers were Borg-Warner transmissions. That is all you can view in the Ford archives too.
Dan Case
Old 02-28-2017, 07:58 AM
Cobra Make, Engine: JCF supplied the body,frame,and some of the driveline-I completed it to be a very accurate 289 slabside
Based on my experience I think anyone considering using a T 10 that might need rebuilding, or any new internal parts, should first find a shop that you were pretty sure could do the job and had the parts to do it. When I built my slabside about 17 years ago I had the T 10 worked on four times before I found a fellow in the San Diego area that knew what he was doing and it finally was perfect. The first rebuild had the input shaft barely engaging the pilot bearing (wrong part obviously). The shop that did the work took it all apart and that problem was solved but a couple more were created- bad gear noise and wrong speedo drive gear. Had more work done at another shop and it was still bad. Third time was a charm. Seems like there was a shortage of good parts, especially matching gearsets, back then and I have a feeling that the situation is even worse now.
Old 02-28-2017, 08:03 AM
Dan Case's Avatar
Ford units are much more robust than the Borg-Warner ones. Ford units that have the same physical installation dimensions as the T10s used in Cobras are not real common anymore. Like most 1960s parts used parts dealers COULD HAVE saved, they are not something desired by 1965 and later Mustang owners so there was no big demand to save them from the scrap heap.
Genuine production aluminum case transmissions as Cobras used are quite expensive as cores that can be rebuilt. Old cases with new old stock internals are insanely costly as the vintage racers have used up most of the available spares since vintage racing started in the mid 1970s. I inquired about a set of M gears in new old stock condition. The place didn’t have an input but all the rest was priced at nearly $6,000 delivered. I didn’t buy what they had because I didn’t have an idea where I would find a new old stock input to complete the set. The spare ex-Cobra transmission I bought cost almost twice as much as the original ex-Cobra engine I bought for a spare also. There are more than a few broken units scattered around in various Cobra owner garages.
Before leaving availability of original Cobra correct aluminum cased T10s, if the original Cobra owner is picky and wants a transmission date correct for their car then their hunt for a ‘correct’ assembly just became enormously harder. Production assemblies had a date of assembly stamped into them.
Ford ‘top loader’ transmissions (not ones somebody cobbled up and you have to get the matching shifter and linkage system also) that ‘bolt in’ to an original Cobra are not cheap as compared to let’s say a Mustang model.
Dan Case
Old 02-28-2017, 08:39 AM
1795's Avatar
Dan and Jon,
Thanks for the information and your thoughts. i had heard that the top loader was more robust than the T10, and that if you found a T10 that was rebuildable it would be very expensive, but wanted to hear the opinions of others as well.
Old 02-28-2017, 09:02 AM
Dan Case's Avatar
Dan and Jon,
You are welcome.
Original privateer Cobras that were raced hard suffered failures frequently. Aluminum tail shaft cases are somewhat fragile and even street and strip use of a street car could lead to breakage. The torque rating of a T10 as used in a Cobra was right at the torque rating of a stock HP289 (I don’t recall the exact numbers anymore.) In drag racing half shafts were known to fail and twisted or broken differential output shafts were common. In chassis before CSX2165 even differential hangers tended to break in any kind of competition.
Original Cobra street cars and SAI team racers are nearly different subjects by early 1964. SAI developed heavy duty (racing) replacements for clutch systems, transmission assemblies, shifting connecting rods, drive shafts, half shafts, differential gears, differential output shafts, differential hangers, rear axles (a.k.a. hubs), rear vertical link and axle bearing system, road springs and holding them in place, shock absorbers, steering system control, throttle pedals, front wishbones (a.k.a. control arms), and many fasteners.
Dan Case
Old 02-28-2017, 09:25 AM
Aluminum T10L cases were reproduced as were the T10M cases, I am not certain if they are still available. T10L and T10M gear sets can be found but as you stated can get expensive. That being said you can always use GM or other manufacturer gearsets, some have more desirable ratios than the Ford specific gear ratios and have a custom clutch disc made, most performance clutch manufacturers offer this service. Updated internal parts are available for the early T10 transmissions to help overcome their week points like popping out of gear (one of the biggest issues). These parts come from the Super T10 which became widely popular in the 70s and 80s for performance applications. You need to locate a Galaxie T10B iron case and tail shaft as this will provide the correct, transmission length, shifter position and mounting. The shifter assemblies can sometimes be an issue to find a rebuildable unit but you can use an aftermarket (Hurst) assembly also. Another issue the factory shifter unit has is the cross pin is smaller on the T10 shifters vs the Top Loaders shifter assembly which uses a larger diameter cross pin, I have swapped out the shifter boxes from the Top Loader to my T10, since Ford made both shifter assemblies they used the same mounting bolt patterns on both. You can put together a Ford Top Loader transmission assembly to bolt in place of a factory T10 transmission too if you desire. The T10 shifting is much smoother than the Top Loader in my opinion.
you might want to check out Richmound Gear, they bought the Borg Warner T10 design and still produce the transmission mostly for racing applications. There are other companies that also produce racing transmissions that utilize the T10 architecture and use such materials as magnesium for the cases. The B Production 289 Kirkham Cobra that we are currently putting together in our shop utilizes one of these hybrid T10 transmissions.
Old 02-28-2017, 10:12 AM
Some people can brake anything. My 1965 mustang came with a iron T10 289 2 barrel carb . Added lots of power including nitrous. Lots of street use and dragstrip use on slicks. Never broke it. Bought a new Richmond gear 5 speed. Broke it the first pass. Box it came in said bullet proof transmission.
The 1963 galaxie T10 that comes behind a 390 had a shorter input shaft than one from a 289. A 390 tranny can be used with a longer pilot bearing.
Galaxie T10's are cheep if you look in the right places. I just saw a couple in the last month for $200 or less. Guys that specialize in trannys think they have gold bars in them. I am talking iron cases not light weight galaxie transmissions.
Here is an iron one.
  #33 (permalink)
Old 02-28-2017, 10:16 AM
Dan Case's Avatar
+1 My opinion also. When everything is meeting OEM specifications T10 shifting is extremely smooth. I had a 1965 GT350 and a 1966 GT350 with T10s, 1969 and a 1970 Boss 302 with Ford top loader, and a 1970 Boss 429 with an enormously heavy version of top loader. With all cars adjusted to OEM specifications I like the gear changing ease and feel in the T10s best.
Dan Case
  #34 (permalink)
Old 02-28-2017, 06:34 PM
xb-60's Avatar
Interesting comments from Jon and Dan.
I considered (but only for a short time) using a T10 for my FIA replica build, but rejected that path early, deciding on the Toploader.
Rationale for going Toploader rather than T10 was….
1. In Australia, Toploaders are available (while not exactly plentiful), but T10 gearboxes are rare. If I had chosen to use a T10, I would almost certainly have had to import one from US.
2. One of the very few David Kee agents is virtually just around the corner from me. T10 experts – as logic would suggest - are even more rare here than T10’s.
3. I wanted a period correct gearbox and the research I did at the time suggested that the Toploader is a very robust gearbox. As well, they were of course consequently used (in modified form) behind the Cobra 427, and used as the basis for the GT40’s Kar Kraft gearbox.
As far as shift action goes, my rebuilt Toploader and Hurst shifter has an action that feels similar (from distant recollection) to the bolt action on a Lee Enfield 303. If the T10 is better, it must be very good.
Glen
  #35 (permalink)
Old 02-28-2017, 06:42 PM
1795's Avatar
Glen,
Glad to hear that your top loader shifts well. Cannot wait to give mine a try. A T10 would put me out of budget and probably be hind schedule as well. If you have any video of you driving your cobra I would like to see and hear it.
Take care
  #36 (permalink)
Old 03-01-2017, 12:24 AM
ALF's Avatar
ALF ALF is offline
Many thanks for this great information!
I got curios about the difference between the T10-B (mentioned by John) and the T10-H (I own) main cases. I found an interesting pdf on the internet which contains some information I’m not able to verify/confirm.
Ford T10s used two iron main case configurations and both main cases are 9 1/2 inches long. The early, narrow transmission mounting bolt pattern T10 B-1 case was used from 1960-64 with 221/260/289 engines that had 5 bolt blocks and the later T10 H-1 case with a dual mounting bolt pattern entered service in late 1964 for use with the 289 and later engines with a 6 bolt block
http://wasaac.org/techdocs/T10.pdf
Driving with your Cobra is fun,
Racing with your Cobra is amazing,
Driving hill-climbing races with your Cobra is.... HAVEN!!
  #37 (permalink)
Old 03-01-2017, 01:31 AM
xb-60's Avatar
.....Glad to hear that your top loader shifts well. Cannot wait to give mine a try. A T10 would put me out of budget and probably be hind schedule as well. If you have any video of you driving your cobra I would like to see and hear it
Jim,
My "shifting" up to this point is on the bench, but indicates a satisfying setup. A video is some time off yet, but looking forward to the time when I can provide one. Good luck with your transmission ....but it seems that you would need more luck and cash if you had gone the T10 route
Glen
  #38 (permalink)
Old 03-01-2017, 08:22 AM
I am a bit puzzled hearing that the T 10 would just barely take the torque of a 271 HP 289. I bought a 65 Mustang K code, with a toploader, new off the lot and that engine never seemed very torquey to me. I remember seeing a 62 Chevy Impala 409/409 right off the showroom floor at the strip and you could see daylight under the front wheels after the flag dropped. How in the heck did the T 10 take that kind of torque? The car came back week after week, and beat everything.
Larry B likes this.
  #39 (permalink)
Old 03-01-2017, 08:25 AM
As ALF brought reference to;
The transition from the narrow bolt pattern to the wide bolt pattern. This transition happened to both the T10 and the Ford Top Loader. The wide pattern Top Loader usually included both narrow and wide bolt patterns. This transition happened at the same time that the 289 engine switched from being a 5-bolt (used on all manual shift 260/289 Cobras) to the 6-bolt configuration. The 6-bolt configuration 289 engine was used on 289 Cobras that were equipped with automatic transmissions.
  #40 (permalink)
Old 03-01-2017, 08:45 AM
T10 transmissions have been installed in nearly all the major auto manufactures most powerful big block powered manually shifted drag cars, 409s GM, 421 Pontiac, 406-427 Ford & Mercury. Yes, evolution within each manufacturer may have lead to each manufacturer developing their own transmissions or the development of improved transmissions but the simple fact remains, the T10 transmissions had been backing some of the most brutal engines built in some of the biggest cars built at the time.
