Old 06-13-2013, 05:32 AM
FatBoy's Avatar
Default 289 Fuel Pumps
What was the original fuel pump configuration on original 289 Cobras? I'm primarily interested in the road cars, but I would also like to know what differences were on the race cars.
Thank you,
Paul
Old 06-13-2013, 07:37 AM
1985 CCX's Avatar
Paul
The small block cars used Carter mechanical pumps up front as Ford provided.
The race cars I have seen without long range tanks added an electriccal SW unit in the left rear of the trunk.
I have seen this configuration in Dragonsnakes (pictured) and a LeMans car each with slightly different positioning however basically the same.
Pictured is my car...
Old 06-13-2013, 08:16 AM
Cobra Make, Engine: built the molds and body composite construction
The Daytona Coupes used three BENDIX (light metalic blue in color) pumps.
Bill K
Old 06-13-2013, 08:28 AM
Russ Dickey's Avatar
Cobra Make, Engine: Unique Motorcars 289 FIA
Before the Carter X pumps were used, didn't the 260s and early 289s utilize a separate fuel filter unit?
Russ Dickey
Mid-America Cobra Club
www.MidAmericaCobraClub.com
Old 06-13-2013, 02:27 PM
A-Snake's Avatar
Original Shelby Owner
Cobra Make, Engine: CSX2321
Correct, mounted to the left head.
Old 06-13-2013, 04:48 PM
Dan Case's Avatar
Default HP289 Cobra Fuel Pump
Cobras with through CSX2125 fitted with mechanical pumps got a 1962 Ford design assembly.
By chassis number CSX2126 and later cars were fitted with the 1963˝ design Carter® 3623S model for all 260/289/HP289 1963 Fairlanes. The earliest dated pump in my database is before HP289s were introduced. The 3623S was a 1963 model year pump for V-8 Fairlanes. The 3623S was replaced in regular Fords with the 3732S for the 1964 model year. Later the 3734S replaced the 3732S. Cobras street and race CSX2126 and later for the 1963-65 model years used the 3623S pump. They could not be used as they were in Fairlanes. Chassis interference on a Cobra created the need for the valve bodies to be rotated forward. The stock Ford steel line would not work with the turned valve body so engine installers cut the steel line above the pump, installed an Eelco® brand 90° elbow fitting, a rubber jumper hose, and two Murray® brand hose clamps.
Dan Case
