Old 09-26-2013, 04:01 PM
Club Cobra Member
Cobra Make, Engine: NAF 427
Default Smith's Tach settings
Just curious as I may have messed up my Smith's Tach settings as I was messing about under the dash.
My Smith's tach has a 8-6-4 cyl rotary switch on the back. If the switch was disturbed and moved to the 4 cyl setting, would my V8 appear to be running at twice its RPM:
Example: the V8 is running at 1000 RPM but the tach says 2000 RPM.
Can anyone help?
Greg
Old 09-26-2013, 09:06 PM
LMH's Avatar
LMH LMH is offline
Not sure but have you switched it back to 8 cylinder? Does it work?
Alba gu brąth
Old 09-27-2013, 07:25 AM
Club Cobra Member
I'll reset the switch this morning and run the car to confirm.
I researched the info on the net and confirmed my suspitions. A 4 cyl fires twice per revolution and an 8 cyl fires 4 times per rev.
So a 4 cyl tach on an 8 cyl engine would read twice the actual engine rpms.
Greg
Old 09-27-2013, 09:35 AM
Club Cobra Member
Here's a pic of the back of my tach. Rotary dial for three settings: 8-4-6 cyl .
But there are four detents as you rotate the dial - see white markings in pic:
Can anyone tell me which is the correct position for 8cyl?
I guess I could do trial and error.
Greg
Old 09-27-2013, 04:39 PM
Club Cobra Member
I've sent an e-mail to Nosinger hoping they can get me an answer before I start a trial and error process.
Anybody have the answer?
Greg
