Like Tree4Likes
  • 4 Post By LMH
Old 04-13-2015, 11:19 PM
LMH's Avatar
LMH LMH is offline
Default 289 SW Speedometer and Tachometer
It took a lot of searching and a number of period SW gauges to rob parts off of to get this right but the end result turned out pretty good!
Alba gu brąth
Old 04-14-2015, 09:31 AM
1985 CCX's Avatar
Soooo sweet!
Kudos
I need to do the same
Old 04-14-2015, 10:47 AM
LMH's Avatar
LMH LMH is offline
Joey at MoMa took all my collected parts and put everything together. Good guy to deal with too. Home
Alba gu brąth
Old 04-23-2015, 08:12 AM
Default s/w tach
hi larry , glad you are enjoying project daytona coupe.
hey the guages are great.
i have the speedo , just need the tach.
i contacted joey , i dont have an old one just the modern one we were going to change the back screen print.
do you have another pointer.?
any other info would be great
cheers paul
Old 04-23-2015, 09:26 AM
LMH's Avatar
LMH LMH is offline
Hey Paul!
Your Daytona project is incredible! Love seeing it go together. I don't have any other needles, sorry.
The needle was one of the parts I had to do a lot of searching for and finally found on an old gauge that was trashed. I bought about six old gauges total to end up with two after Joey finished. I think I found the correct needle on an old tractor tach that had an electric tach drive attached to the case. I did find other needles that were close but we're too short once I actually got them, so look carefully at photos if you search for one. I sent everything I had collected to Mo-Ma and he put them together using a VDO drive for the tach internals. That way, I don't have to use a separate tach drive as the originals did.
Alba gu brąth
