Like Tree3Likes
  • 1 Post By rsk289
  • 1 Post By LMH
  • 1 Post By 1985 CCX
Old 05-25-2015, 07:28 AM
rsk289's Avatar
Cobra Make, Engine: 289 leafspring, r/p
Default Hood prop
Anybody know if the hood prop rod should have a bend in it?
It sits very close to the Autolite alternator and restricts adjustment unless I put a slight bend in it.
Roger
Old 05-25-2015, 08:23 AM
LMH's Avatar
LMH LMH is offline
Yes, up near the pivot mount by the firewall. I have a photo I can post later this evening when I get to my computer.
Alba gu brąth
Old 05-25-2015, 12:03 PM
LMH's Avatar
LMH LMH is offline
Note the bend on the rod.
Alba gu brąth
Old 05-25-2015, 12:19 PM
LMH's Avatar
LMH LMH is offline
Here's another.
Alba gu brąth
Old 05-25-2015, 02:13 PM
rsk289's Avatar
Thanks for the pictures Larry, some great detail in there. Yes, I do have the bend in the vertical plane to drop the rod lower down. My concern was with the horizontal plane - after the bend shown in your pictures, my prop rod is dead straight in all planes. This means that where it passes the alternator it sits away from the aluminium panelling of the inner wing and therefore restricts sideways movement of the alternator, limiting adjustment. Should there be a lateral bend anywhere, most likely level with the alternator?
Roger
Old 05-25-2015, 03:32 PM
LMH's Avatar
LMH LMH is offline
I know 2367 also has a bend in the rod about or a little before it meets the aluminum splash panel. Unfortunately, I don't have a photo that shows that.
It would allow the rod to pass by the alternator I think.
Alba gu brąth
Old 05-25-2015, 03:41 PM
rsk289's Avatar
Thanks Larry. It would make sense, but I don't want to go bending things until I'm sure. Better a slight bend than clouting the alternator!
Edit - yes, just managed to find some pictures from the old CSXinfo site, and a number of cars are shown with the prop up. There is indeed a bend just level with where the prop would sit next to the alternator in the 'down' position, so a bend it is.
Roger
LMH likes this.
Old 05-25-2015, 06:04 PM
1985 CCX's Avatar
Let the bending commence.
Pictures.....
Old 05-25-2015, 07:27 PM
LMH's Avatar
LMH LMH is offline
Ha... I did have one after all!
xb-60 likes this.
Alba gu brąth
Old 05-25-2015, 07:31 PM
Fast289's Avatar
Cobra Make, Engine: FFR 289 FIA 347 Stroker
Great pictures Larry, my prop is laying on WildHorse EAST track somewhere. Easier to replace the prop versus fixing my sidepipe at the track. BTW, I blew out my passenger rear tire tracking and now have matching flat bottom pipes. Looks symmetrical now....
Dave from Chandler.
Old 05-25-2015, 10:29 PM
LMH's Avatar
LMH LMH is offline
Geez Dave, you've left pieces of your car on some great tracks!
We had a ProAutoSports event last weekend at Inde. You should have come down. Was a big event.
Alba gu brąth
Old 05-26-2015, 12:18 AM
rsk289's Avatar
Thanks Larry, that shows it perfectly. And I see it's a curve rather than a bend. Dan has told me the rod is tubular, not solid, so any bending will need to be done 'delicately'!
I guess it's time I posted a 'progress' pic... I'll see what I've got
Roger
Old 05-26-2015, 07:01 AM
Fast289's Avatar
Larry, I was in Sedona pissing of all the liberals with my loud polluting car! So much for the piece and quiet for hikers and bead threaders.
Dave
Dave from Chandler.
Old 05-26-2015, 08:45 AM
1985 CCX's Avatar
Who is that goofball in the Cobra shirt judging that gorgeous car?
Old 05-26-2015, 12:15 PM
LMH's Avatar
LMH LMH is offline
Good job Dave! Keep them on their toes!
Is that you Jeff?
Alba gu brąth
Old 05-26-2015, 01:48 PM
1985 CCX's Avatar
Yup.......
LMH likes this.
