Old 08-22-2016, 09:57 AM
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Default OE 289/FIA Side exhaust mounts...
Hi All,
Would anyone have detailed drawings of the side exhaust mounting tabs and locations on the chassis for the 289/FIA? I believe the forward one is mounted under the cowl/scuttle hoop.. 1.25" wide with 3/8 slot in it ?? The rear one seems like it bolts under the outer seatbelt mount???
Thank you,
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
