5Likes
Post By A-Snake
Post By rsk289
Post By xb-60
Post By CompClassics
Post By BJ's Snake
05-18-2017, 10:55 PM
NSW
CSX 2431 Dash
Hi Guys.
After any close up pics of CSX2431 dash layout with gauge sizes as it looks like Ken Miles used a different Tach to most.
It looks as if the speedo is 3 3/8 but are the others 2 5/8 oor 2 1/16?
Also not sure of which ones used Fuel level, fuel pressure, oil pressure, ammeter, Water temp ??? etc.
Have scourered the net but hard to read detail on most pics.
Brett
289 FIA Cobras RULE!
05-19-2017, 06:31 AM
The small gauges were 2-5/8", with a fuel pressure gauge. I don't know whether they came with a Stewart-Warner or Smith tach initially, but Gurney's car had a 90-degree Sun tach as raced. As of last year, someone was making a reproduction of the Sun tach. Apparently, the Sunpro is currently unavailable, but there's a Bosch unit that's similar.
See
http://erareplicas.com/cars/142/index.htm
05-19-2017, 09:39 AM
I think 2431 had a large diameter Smiths tach.
Alba gu brąth
05-19-2017, 03:59 PM
Cobra Make, Engine: CSX2321
This is CSX2431 dash.
05-20-2017, 04:15 PM
n/a
Looks like a Smith's chronometric tach to me.
05-21-2017, 07:42 PM
SA
I agree. Large diameter Smiths tacho.
On the Shelby American Collection website ... https://shelbyamericancollection.org...dster-csx2431/ ...under the heading “The Ken Miles Car” the tacho is described as "The big Smiths 'tell-tale' tachometer rotated so it was easy to read at high rpm"
Glen
05-22-2017, 12:26 AM
n/a
Originally Posted by xb-60
...so it was easy to read at high rpm"
...for as long as it was working. I've run a couple of these in restored cars and they are extremely complex, slow to respond (they move in 'jumps', not smoothly, following the revs rather than showing them instantly), and very fragile!
Roger
05-23-2017, 10:35 AM
Smiths Chronometric mechanical tachometer. This tachometer movement is very much like a chronometric watch or clock and has been used in everything from production motorcycles to Formula 1 race cars. It is a very accurate method of gauging engine revolutions and some of the various models used had a resettable "telltale" needle that recorded the highest rpm the driver reached. If you look at most Formula 1 race car instrument panels you will notice a Smiths Chronometric tachometer being used, maybe even as late as the 1980s. These tachometers were available in different drive ratios depending where the tachometer was to be driven from, crankshaft (Cobras), distributor, camshaft, etc. . SAI transitioned from the SUN electric tachometers on early and up to the first couple of FIA competition 289 Cobras to the mechanical Smiths Chronometric tachometers. Depending on the particular model these can be expensive, STACK makes an electric tachometer that has the appearance of the Smiths but is electrically operated and has "telltale" capability, in fact they even reproduced the needle movement to mimic the Smiths Chronometric tach.
As per the statement above regarding "following the revs", all tachometers follow the revs, that's what tachometers do. Mechanical tachometers are more instantaneous than electric units.
Clocking the tachometer or any gauge for that matter is done so that it is easier to notice through your peripheral eyesight vs directly taking your eyes off the road to look where gauge needles are pointed.
05-23-2017, 05:21 PM
SA
Agreed on the Stack tach. Their ST230C is one I considered. It's a 5" so might suit the look your after.
ST200C & ST230C Classic Tachometers
Glen
05-23-2017, 06:22 PM
NSW
Thanks for the replies Gents.
Will probably go with this.
5 inch and reverse sweep.
Brett
