Like Tree6Likes
  • 4 Post By Dan Case
  • 2 Post By Dan Case
Old 06-06-2017, 03:57 AM
Cobra Make, Engine: AC 289HP
Default Anti rattle door buffer
Has anyone a picture of the rubber buffer that's fixed to the A post that helps the door from rattling on a 289?
Old 06-06-2017, 01:12 PM
Dan Case's Avatar
Original Shelby Owner
Very early Cobras with bolt in brass pin, metal washer, rubber washer, and hex nut? (Same as late AC ACE and ACE RS2.6 chassis.)
Or
Most Cobras, win a push in rubber bumper (same bumper used with AC Cars supplied standard side windows).
About ten years ago I collected original samples from several cars covering production of most Cobras and all 427 Cobras. I reverse engineered the design, had a mold made, and had hundreds of parts made for individuals and shops that wanted some so there are still probably some new ones around as spares still.
This is drawings I came up with to have new parts made.
Dwight, LMH, Mongoose930 and 1 others like this.
Dan Case
Old 06-08-2017, 12:22 AM
Default Rubber Buffer
Great picture Dan, but how is it fixed to the scuttle? and where!
Old 06-08-2017, 05:12 AM
Dan Case's Avatar
A hole is drilled in the A pillar in line with the socket in the door. The socket gets filled with a flat head screw
Dan Case
Old 06-08-2017, 05:44 AM
BAsque1's Avatar
Where can these bumpers be obtained today, part #?
Basque1
Old 01-11-2018, 03:06 PM
Dan Case's Avatar
Picture of new replacement part replaced with drawings.
DRED and coowilla like this.
Dan Case
Old 01-12-2018, 04:29 AM
Steele Rubber Products. part no. 33-0368-30 Licence plate plate buffer. Pretty close
Old 01-12-2018, 07:34 PM
LMH's Avatar
LMH LMH is offline
Your link took me to an ad for tire chains. Try this one: https://www.steelerubber.com/license...per-33-0368-30
Alba gu brąth
