Like Tree6Likes
Old 04-17-2020, 04:14 PM
Ivygreen65's Avatar
Default 289 Fuel neck / cap location
I’m about to have the fuel tank made for my 289 street car. In order to have the tank’s filler neck in the correct location to connect with my Ceandess cap/neck, does anyone have measurement for the distance between the boot lid and the neck/cap?
Old 04-17-2020, 05:59 PM
xb-60's Avatar
Originally Posted by Ivygreen65 View Post
....289 street car....?
Is it an original car, or a replica. If replica, which one? Is the fuel tank upright or flat?
Here's what mine looks like....
Glen
Old 04-17-2020, 07:42 PM
Cobra Make, Engine: ERA 3012
Here's is the measurement on my ERA. Let me know if you need any others.
1985 CCX likes this.
Old 04-18-2020, 06:23 AM
Ivygreen65's Avatar
Mine is a replica, but I’m having a tank similar to the original 289 tank built for it. You can see the mock-up I built in this pic.
1985 CCX and A/S65 like this.
Old 04-18-2020, 06:25 AM
Ivygreen65's Avatar
Thanks, Andrew. That’s the dimension I’m looking for.
Old 04-18-2020, 07:43 AM
jolsen42's Avatar
Stacy, check this link and in one of the pictures it shows that the measurement is actually 3 1/2 inches from the body edge. That's the spacing that I used.
John O
https://photos.google.com/share/AF1Q...YwS2tadG5XQTd3
Stacy, here is a picture of my gas filler.
jjo42
Old 04-18-2020, 08:18 AM
Ivygreen65's Avatar
John,
Thanks for the info. I have the pic you reference in my archive and it adds to my confusion. It shows +/- 3.25” to the CENTER of the fill neck, while AndrewB’s photo shows about 3” to the EDGE of the cap (equating +/- 4.5” to the center of the neck). Since the top (when installed) is in pretty close proximity to the cap, I don’t want it to be too far forward. Furthermore, I would like to have it in a relatively correct location. Finding top view photos of original cars are somewhat rare, so I can’t find much reference material that would allow me to scale.
Old 04-18-2020, 09:01 AM
jolsen42's Avatar
Well other than Mike's link I don't know what to tell you. Mike's(MAP) chassis is an original so the placement of 3 1/2" from edge to center of fill should be perfect. I suggest you don't drill the hole until you get your tank.
John O
jjo42
Old 04-18-2020, 09:17 AM
Ivygreen65's Avatar
I’m definitely not drilling the hole until I have the tank. However, my drawing for the tank fabricator has all dimensions except how far off the tank body the filler neck extends. And, since the tank will only be able to move laterally about 1/4” after it’s installed, I want to make sure that neck extension dimension is correct. I’m hoping to pin this down by Monday so I can send them a final drawing.
Old 04-18-2020, 10:11 AM
CompClassics's Avatar
If you give me a couple of hours I can get you an original 289 Cobra measurement. I just removed a tank from a street car for repairs.
Old 04-18-2020, 10:23 AM
Ivygreen65's Avatar
That would be excellent. Thank you.
Old 04-18-2020, 12:27 PM
LMH's Avatar
LMH LMH is offline
Is this the measurement you're after?
Alba gu bràth
Old 04-18-2020, 01:09 PM
I forgot, I have two in the shop right now, both measured 3 1/2”.....
LMH likes this.
Old 04-18-2020, 01:43 PM
Ivygreen65's Avatar
That’s perfect. Thanks to everyone who posted. I appreciate the help.
Old 04-18-2020, 02:28 PM
LMH's Avatar
LMH LMH is offline
Your mockup tank is pretty cool! Nice job! You could even put mounting tabs like the original has on the sides and strap it in.
Alba gu bràth
Old 04-18-2020, 02:41 PM
Senile Club Cobra Member
I have have an original type aluminum tank for a 289 street car available.
rick@autoventureusa.net
Old 04-18-2020, 04:04 PM
jolsen42's Avatar
Stacy, 3 1/2" would I ever steer you wrong?
John O
jjo42
Old 04-18-2020, 04:21 PM
Ivygreen65's Avatar
My ex-wife used to say the exact same thing 😉.
Old 04-18-2020, 04:30 PM
jolsen42's Avatar
Yeah, but I was right. but if that is your comparison, well don't ask me any questions.
John O
jjo42
Old 04-18-2020, 04:39 PM
Ivygreen65's Avatar
You were spot on. Thanks for the info.
