Like Tree5Likes
  • 3 Post By MOTORHEAD
  • 2 Post By Tommy
Old 11-05-2021, 11:08 AM
Default throwout bearing/slave cylnder?
Hi, I am running a 302 and t5 trans. Would the best thing to use be a hydraulic slave/ throwout bearing? it would allow only two hydraulic lines to be installed.
thanks for your help.
Old 11-05-2021, 11:47 AM
twobjshelbys's Avatar
The HTOB died twice in less than 500 miles.
I switched to the traditional master/slave setup and never had another problem.
CSX4005LA
Old 11-06-2021, 06:22 AM
Using McLeod bolt-on (1300 series) HTOB now.
3 years and 4000 miles running with no problem at all.
Mounted to a McLeod clutch, big input Toploader (1-3/8") and BBF.
https://www.mcleodracing.com/1300-series-bearing-/p104
Note:
Old 1st generation units were problematic.
The current redesigned model appears to be reliable.
McLeod provides a few spacers to properly shim the HTOB.
I took a measurement and had a single shim machined
as opposed to a stack of smaller ones to get the proper spacing.
1400 series is the slip-on variant.
McLeod has HTOB rebuild kits available.
Replacement components at Summit Racing:
https://www.summitracing.com/search/...ent-components
How to rebuild video here:
https://www.youtube.com/watch?v=K39CNwrTv2o
Old 11-06-2021, 08:53 AM
MOTORHEAD's Avatar
Repairing/replacing the HTOB is not a problem, its the removing/reinstalling of the tranny/engine to get to it !
"When Injustice becomes Law,
Old 11-06-2021, 08:09 PM
Tommy's Avatar
Put me in the camp with those who pulled the transmission multiple times to deal with a leaky EARLY HTOB. I switched to a mechanical TOB and clutch fork moved by an externally mounted hydraulic slave cylinder. It worked with no further problems. 351 Windsor with Richmond transmission.
eschaider and hauss like this.
Tommy
Previously owned EM Cobra
Old 11-07-2021, 02:53 AM
Get the mike Forte kit and do it only once
CSX4005LA
Old 11-07-2021, 08:27 AM
cycleguy55's Avatar
My 30 year old McLeod HTOB still works fine, and no leaks. I do note, however, the new ones seem to be made differently - I think mine's all steel.
Brian
Old 11-16-2021, 03:07 PM
thanks for the help. looks like it's a mixed bag and will have to make the choice myself and pray a lot.
jim
Old 11-16-2021, 08:21 PM
hauss's Avatar
Not if you count the likes. I will say the internal ones seem to have a easier petal. Not hard to set up but easy to mess up the set up. Way more work to fix. Higher failure rate due to location. For those reasons alone I would recommend a external set up. I have installed both on different cars so trust me when I say I know what I am talking about.
Old 11-17-2021, 11:00 AM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Newer production cars with manual transmissions use HTOBs with little problem. Many aftermarket HTOBs simply use an o'ring as the seal and durability is poor. I know that the Tilton HTOB uses an actual seal designed for the purpose and the durability should be significantly better.
Old 11-17-2021, 02:19 PM
hauss's Avatar
Most newer production cars use automatics ,also I was talking about tremec transmissions with various clutches all cars were 450 and above hp.
