Like Tree5Likes
  • 1 Post By Tommy
  • 1 Post By LMH
  • 1 Post By LMH
  • 2 Post By Dan Case
Old 12-12-2021, 06:36 AM
Default Dual circuit braking system conversion
Good afternoon fellow cobra enthusiasts,
I want to convert my original car (CSX214X) from a single to a dual circuit braking system.
I still runs its original Girling 0625 unit.
I do not want to cut the frame or chassis but cant find any tandem / dual brake cylinder with external reservoirs…
Thanks a lot in anticipation,
Marius
Old 12-12-2021, 06:58 AM
Tommy's Avatar
Would this work?: Wilwood
mvanhorn8893 likes this.
Tommy
Previously owned EM Cobra
Old 12-12-2021, 07:06 AM
LMH's Avatar
LMH LMH is offline
My intial thoughts would be to replace the pedal box with one made for dual masters. CSXParts.com has the master cylinders, bias bar, clevises, etc but I don't think they sell a box. Mght want to contact them.
Marius_289 likes this.
Alba gu brąth
Old 12-16-2021, 01:31 AM
Hello Gentlemen,
I know it’s usually done by replacing part of the pedal box with a new one to make space for two single brake master cylinders, but apart from ruining the side view of the cars I do not want to cut anything and leave the chassis completely unmolested.
Is there no solution with a Tandem / double master cylinder? It just needs a small bore, less than 1 inch..
Cheers & happy xmas season,
Marius
Old 12-16-2021, 03:59 AM
Tommy's Avatar
So, the link I offered won't work?
Tommy
Old 12-16-2021, 05:39 AM
What am I not seeing here. Does it not have dual master cylinders? Does this not serve the same purpose as a dual circuit cylinder?
Old 12-16-2021, 07:43 AM
Tommy's Avatar
I'm assuming this is what he has:
Tommy
Old 12-16-2021, 07:52 AM
Yes Tommy but his car should have 2 of them. So what is to be gained by changing to the one you linked to?
Old 12-16-2021, 08:40 AM
CompClassics's Avatar
Hi Marius 289
Could you give us a little history on how long you have owned this Cobra?
Old 12-16-2021, 12:12 PM
cycleguy55's Avatar
0.625" bore: https://wilwood.com/MasterCylinders/...emno=260-11097
7/8" or 15/16" bore: https://wilwood.com/MasterCylinders/...ter%20Cylinder
Brian
Old 12-16-2021, 02:51 PM
LMH's Avatar
LMH LMH is offline
Single master/single circut until CSX2164.
Tommy likes this.
Alba gu brąth
Old 12-16-2021, 04:06 PM
Really I did not know that! Any chance you have a picture of one of those brake boxes?
Old 12-16-2021, 04:27 PM
Dan Case's Avatar
Original Shelby Owner
Default CSX2165 onward
The enclosure stayed much like CSX2001-CSX2164 cars. A.C. added an aluminum adapter and all the parts to make two brake circuits for CSX2165-CSX2200 cars.
At CSX2201 a new larger enclosure was added as part of the welded chassis.
CSX2165 was also the first car to get steel differential hangers instead of the cast iron original which had a breakage problem.
LMH and MAStuart like this.
Dan Case
Old 12-16-2021, 06:26 PM
LMH's Avatar
LMH LMH is offline
I don't, sorry!
Alba gu brąth
