| S |
1 |
| 5 |
8 |
| 12 |
15 |
| 19 |
22 |
| 26 |
29 |
30 |
5Likes
Post By Tommy
Post By LMH
Post By LMH
2
Post By Dan Case
12-12-2021, 06:36 AM
Dual circuit braking system conversion
Good afternoon fellow cobra enthusiasts,
I want to convert my original car (CSX214X) from a single to a dual circuit braking system.
I still runs its original Girling 0625 unit.
I do not want to cut the frame or chassis but cant find any tandem / dual brake cylinder with external reservoirs
Thanks a lot in anticipation,
Marius
12-12-2021, 06:58 AM
AL
Would this work?: Wilwood
Tommy
Previously owned EM Cobra
12-12-2021, 07:06 AM
AZ
My intial thoughts would be to replace the pedal box with one made for dual masters. CSXParts.com has the master cylinders, bias bar, clevises, etc but I don't think they sell a box. Mght want to contact them.
Alba gu brąth
12-16-2021, 01:31 AM
Hello Gentlemen,
I know it’s usually done by replacing part of the pedal box with a new one to make space for two single brake master cylinders, but apart from ruining the side view of the cars I do not want to cut anything and leave the chassis completely unmolested.
Is there no solution with a Tandem / double master cylinder? It just needs a small bore, less than 1 inch..
Cheers & happy xmas season,
Marius
12-16-2021, 03:59 AM
AL
So, the link I offered won't work?
Tommy
12-16-2021, 05:39 AM
IL
What am I not seeing here. Does it not have dual master cylinders? Does this not serve the same purpose as a dual circuit cylinder?
12-16-2021, 07:43 AM
AL
I'm assuming this is what he has:
Tommy
12-16-2021, 07:52 AM
IL
Yes Tommy but his car should have 2 of them. So what is to be gained by changing to the one you linked to?
12-16-2021, 08:40 AM
Ca
Cobra Make, Engine: SAI FIA, 289HP (5-bolt), 48IDA Webers
Hi Marius 289
Could you give us a little history on how long you have owned this Cobra?
12-16-2021, 12:12 PM
SK
Brian
12-16-2021, 02:51 PM
AZ
Single master/single circut until CSX2164.
Alba gu brąth
12-16-2021, 04:06 PM
IL
Really I did not know that! Any chance you have a picture of one of those brake boxes?
12-16-2021, 04:27 PM
CSX2165 onward
The enclosure stayed much like CSX2001-CSX2164 cars. A.C. added an aluminum adapter and all the parts to make two brake circuits for CSX2165-CSX2200 cars.
At CSX2201 a new larger enclosure was added as part of the welded chassis.
CSX2165 was also the first car to get steel differential hangers instead of the cast iron original which had a breakage problem.
Dan Case
12-16-2021, 06:26 PM
AZ
I don't, sorry!
Alba gu brąth
