Old 09-07-2024, 11:28 AM
Cobra Make, Engine: KCC Venom (BDR)
Default Girling slave cylinder setup
Hi all,
Does anyone perhaps have a photo of what the original Girling slave cylinder and bracket setup looked like? I would like to confirm how the bracket attached to the block and then the stiffener z bracket.
Any assistance will be appreciated.
Old 09-07-2024, 12:20 PM
1985 CCX's Avatar
I can when I get home later
Honey do’s at moment
Do you have proper brackets ?
Also ………
FE power ?
Windsor power ?
They are different of course ��
Old 09-08-2024, 09:36 AM
I have the proper brackets for an FE. Thanks
Old 09-08-2024, 05:11 PM
1985 CCX's Avatar
The SB first
FE is second
The z backer runs from bellhousing to slave.
Old 09-09-2024, 01:28 AM
Thanks a lot for the photos. I have the exact bracket for my FE. What I am wondering about is why does the bracket have a boss/spacer on the bottom bolt where it bolts to the block? What is used to make u this distance at the top bolt?
Is the bottom fastened to the block with a short bolt or is there a threaded rod that runs through the block flange to tighten the bellhousing on the one side and then the salve bracket on the other end?
Old 09-09-2024, 05:40 AM
1985 CCX's Avatar
The spacer is ther eand angled as the block is angled. This keeps it straight.
I'll have to look at the attaching point as one of my 427's is on the floor with jack stands and the other in the car.
Top bolt is a solo bolt as I remmeber.
Bottom one let me look later today.
Old 09-15-2024, 10:22 AM
This is what my setup looks like. The block is angled but not all that much actually. I still would like to know what the bottom bolt/stud setup is like.
Old 09-15-2024, 02:53 PM
1985 CCX's Avatar
Mine fits same way but lower spacer angled like block itself.
Seems something is off
Old 09-15-2024, 03:51 PM
1985 CCX's Avatar
Only two holes in block.
Block is tapered hence the spacer
Old 09-17-2024, 02:59 AM
Thanks. Is the lower mounting held by a nut fastened to a longer bellhousing-to-block bolt or a long stud with a nut on the bellhousing side and a nut on the slave bracket side?
Old 09-19-2024, 02:14 PM
Cobra Make, Engine: Unique FIA
To 1985 ccx, I NEED a part number for the SB version.
Please Please Pretty Please.
My DA engine installer decided on his own do some "custom" fab work.
Well, where's my mount?
"I carried off scrap yesterday"?
Mine was a "one off " that looked much like that. The original builder was a machinist.
Old 09-19-2024, 02:16 PM
Old 09-19-2024, 02:23 PM
Old 09-19-2024, 02:31 PM
sorry, slow internet.
Old 09-20-2024, 02:36 AM
Cool Well...
...I hear an echo again in here!!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 03-03-2026, 11:45 AM
Removed, Duplicate post
Old 03-03-2026, 11:49 AM
So, I check my other block C6ME and the offset to the bracket is exactly the same. Seems that I will need to "adjust" the bottom spacer.
Is the lower bolt a long bolt that protrude through the block with a nut that fasten the bracket?
Does someone perhaps have a photo of the bracket, slave cylinder and Z bracket installed? I have searched the net plenty and cannot get such a photo. It will be appreciated.
Old 03-05-2026, 02:38 PM
Senile Club Cobra Member
https://www.csxparts.com/collections...-bolt-aluminum
rick@autoventureusa.net
