Old 11-01-2008, 08:38 PM
mickmate's Avatar
Default 289 Motor Mounts
Anyone know what they were from? They have two vertical bolts with a clearance hole between them. 289 Stang?
mickmate
http://www.actoncustom.com/
Last edited by mickmate; 11-02-2008 at 05:35 AM.. Reason: Changed stud to bolt duh
Old 11-01-2008, 09:57 PM
cab cab is offline
Cobra Make, Engine: hurricane,# 1060
I use'd a 1970 mustang motor mount on my 289.
www.tni.com/craig-baker
Old 11-02-2008, 05:01 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Long ago I looked into this and purchased a pair which were from a 63-64 Galaxie. My boxes only have the numbers 2220 & 2221. I do not have the Ford designation.
Take that for what it is worth because I have not mated the motor to the frame nor can I find the source of the part # ... I could be wrong
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
Old 11-02-2008, 05:17 AM
mickmate's Avatar
Thanks guys. I'm seeing the same thing on motor end. Frame end has two bolts up and down instead of the stud in the middle. I wonder if they were through bolting the rubbers or some other hot rodder modification. Let me see if I can attach an image [IMG]http://www.clubcobra.com/photopost/showphoto.php?photo=61925&ppuser=10964[IMG]
mickmate
Old 11-02-2008, 05:20 AM
mickmate's Avatar
Try again rrrrrrrr
mickmate
Old 11-02-2008, 05:32 AM
mickmate's Avatar
Sorry lads I gotta practice a little more
mickmate
Old 11-02-2008, 05:33 AM
Fox's Avatar
Fox Fox is offline
This is what I have... I have taken a minute to quickly search a few mustang sites and I do not see a two stud type... Calling Kris Kincaid
mickmate's Avatar
Screw it check my gallery
http://www.clubcobra.com/photopost/s...5&ppuser=10964
mickmate
Old 11-02-2008, 05:35 AM
Fox's Avatar
Fox Fox is offline
... -John
Old 11-02-2008, 05:39 AM
mickmate's Avatar
Thanks John, see how they used the two small holes to bolt it in. The center one just looks like a clearance hole. So just drill and tap two holes in the bottom plate and cut the stud short?
mickmate
Old 11-02-2008, 05:47 AM
Fox's Avatar
Fox Fox is offline
Looking at the mount I have may be too narrow for a upper and lower bolt...
Don't some of the 427 guys cross bolt their motor mounts due to excessive vibration... it can be done safely, right?
Old 11-02-2008, 06:15 AM
KarlCSX2498's Avatar
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
Default 289 mounts
Hello, The 289 mounts are not like the hi po mustang mounts. The mounts have the C shaped piece that bolts to the block and under that it has a rectangle shaped piece of rubber that is approx. 2.5" thick and on the bottom of that is another piece of steel that has the two bolt hole to secure to the chassis motor mounts.
I will try to snap a photo later today and post here.
Later, karl
Old 11-02-2008, 07:05 AM
Default 289
Nick,
Have sent you pics and what you require. Will dbl check later.Regards
Ross
Old 11-02-2008, 08:31 AM
Fox's Avatar
Fox Fox is offline
mk2gt40... thanks for the communal effort.
Nick when you get the chance could you pass them on to me too...
Old 11-02-2008, 08:43 AM
Cobra Make, Engine: 396W Kirkham KMPS036
Karl's verbal discription is pretty close. The rubber block and the donut which connect the motor to the chasis mounts are still available. They are from a 289 Hi-Po engine setup and some of the mustang shops (like Unlimited) still stock them. The U shaped channel which attachs to the engine is much harder to find. They show up on e-bay every now and then. I have found them on 63-64 Hi-Po motor applications. Fran Kress also had some awhile back. Once in a great while McCluskey has some made.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 11-02-2008, 08:50 AM
Fox's Avatar
Fox Fox is offline
Are these the rubber portions of the mount you are describing???
From the Unlimited Mustang site:
Old 11-02-2008, 11:00 AM
Fox,
Yes. The channel engine mount is sandwiched between the donunt and the lower solid block. The solid block then mounts to the chasis in at least 3 different ways that I know of. My Kirkham and all the other 289's have a welded platform on the 3" tube chasis that the block is secured to. Some of the ones I have bought on ebay have a platform that is designed to bolt to a square/rectangular chasis member (63 Falcon). The channel piece is the trick to find. Send me a pm and I'll email you some pics that I think I have.
Bob McLinden
ERA FIA 2080 SOLD
Kirkham KMPS036
Old 11-02-2008, 12:18 PM
Default 289 mounts
Hey John, Yes, that is the exact piece of rubber as on CSX2498. The two cut outs on the sides of the rectangle piece of rubber is where the two bolts & nuts go thru to attach the mount to the chassis.
Later, karl
Old 11-02-2008, 02:33 PM
289ACE's Avatar
Cobra Make, Engine: 2 AC Aces, 1 w/289, 1 w/TBD
Nick,
If it is any help, the mounts I have are set up for the dual bolt holes as shown on the original pedestals and carry the Fomoco P/N C30A-6038-A. On the Ace I have with the 289 in it, it has the same mounts and the 2 bolt holes are through holes and use a bolt and nut to attach the mount to the pedestal.
Jay
Old 11-02-2008, 03:07 PM
289ACE's Avatar
I went out to the shop and compared the mounts I have against the pics above and they look the same except on the ones I have, there are holes in the metal base plate to retain the bolts instead of just a notch where the bolts go. With the new versions, I guess since there is a notch on both sides it holds the mount in place OK?
Jay
