Go Back   Club Cobra > For Sale > Parts Wanted
Old 10-31-2001, 07:42 PM
Cobra Make, Engine: B&B w/FRPP 347ci 450HP Crate
Send a message via AIM to OhBuoy
Default 8.8 5 lug disk rear end
I am looking for an 8.8 mustang 5 lug disk rear end. Prefer 3.27 or higher gear ratio and close to Chicago or willing to ship at a reasonable rate.
Old 03-08-2003, 07:28 PM
Default rear end
i have a ford 9inch not sure what gears 5 lug, just needs new drums otherwise ready to bolt in. 450.00 or best offer i live in the chicago area
Old 03-08-2003, 11:49 PM
Heck yeah, go for a 9" anyday!
Ernie
Old 03-09-2003, 05:40 AM
Default rear end
okay just let me know when you want to come pick it up
Old 03-09-2003, 05:41 AM
Default rearend
i can give you directions, I live right off roosevelt rd in lombard. I will give more detailed instructions
Old 03-09-2003, 05:49 AM
Clois Harlan's Avatar
I originally built my Cobra with a 3.27:1 rear end and found it was too high geared. I assume you are probably running a T-5 or Tremic in which case you may want to consider at least 3.50 : 1
gears. I switched to 3.73 : 1 rear end and it made a tremendous difference in the performance. Just taking off from a stop light became much easier and my overall performance improved as well.
Just some thoughts if you are going to spend the money. Do a search in this section for a chart that Jeff Frigo provided me within the last two weeks. His chart will allow you to put in your transmission, rear gears and calculate the speed at various RPM's.
Clois
"Let's roll"
"Be part of Something Good
Old 03-09-2003, 05:52 AM
Here is the chart if I copied it correctly: If not it is under "Speed/RPM Calculations" on the second page back under "Shop Talk"
http://www.smokemup.com/auto_math/mph_range2.php
"Let's roll"
