02-28-2003, 08:49 AM
FL
Cobra Make, Engine: EverettMorrison,408W,Jag rear, toploader
Tommyboy, the carbs and manifold are the natural finish. The carbs right now have the 1 1/2" high spun aluminum stacks from Inglese with shortened auxilary venturis for hood clearance. I would also give you the 2 1/2" steel stacks that came with the carbs. I have all brand new fuel lines, linkage, pressure regulator and pressure guage from Inglese. They have the screens and filters. Also brand new from Inglese. They are set up with 37mm main chokes. I don't remember for sure what the emulsion tubes and jets are right now, as I am at work and my memory is not what it used to be. I set them up per Enzo's suggestions. I'll let you know when I get home. I have some pictures of them on my car which I will scan and send to you. I'll have to take the other pictures some time this weekend. They are not plumbed for common vacuum but there is one 1/4" port for each throat drilled in the carb. boss on the manifold for adjusting with a mercury column. The whole setup is complete, ready to bolt onto the motor.
