Go Back   Club Cobra > For Sale > Parts Wanted
Old 03-09-2004, 05:56 AM
Default vacuum secondary top
i am looking for a original top for the vacuum diaphram with the vacuum nipple to connect two four carbs.any help appreciated. thanks
Old 03-09-2004, 06:59 AM
MIKE SCHULZ's Avatar
Cobra Make, Engine: Contemporary 427 CCX 3627 ,TKO 600 RR,TWM 58mm DFI
Sir; If you are not concerned with "originality", you can actually make these tops by drilling + installing a brass 90 Degree Fitting that goes from Pipe to hose ( They self thread). I sourced my out through the local Pet Fish Store ( Fish Tank fitting)....About $.25 ea. Looks good - Works Good!....Take Care..Mike
Old 03-09-2004, 07:10 AM
Mr.Fixit's Avatar
I used to make them without threaded fittings. Just drill the hole, insert a 1"long piece of tubing,epoxied in place with loctite 5 minute epoxy.
Mike's idea sounds worthy of trying as well.
Old 03-09-2004, 07:23 AM
restoring a r code fairlane. would like to get an original. thanks for the ideas though.
HTML code is On
