Go Back   Club Cobra > For Sale > Parts Wanted
Old 03-29-2006, 08:51 AM
Banned
Question Wanted: Portable Air/Fuel Ratio meter
Is there a portable (and let's add affordable...say under $400) air/fuel ratio meter that does NOT require tapping a hole and installing a bung for the sensor? I'm thinking of those pipe sniffers that the smog guys attach to your tailpipe with a spring clip, but in a compact, hand-held readout?
Everything I see on the market requires a hole and welding. There are exhaust temperature gauges, but that only gives you a rough estimate if a cylinder is running rich (low temp) or lean (high temp).
Yeah, I know a quick trip to a chassis dyno would be cheaper, but I'm a serious DIYer and love to tinker. I really think there is a market for this type of device. Thanks for any links or insight!
-Dean #747
Old 03-29-2006, 09:23 AM
CobraEd's Avatar
I think that there may be a direct and consistently repeatable relationship to temp of the header near the exhast port and the A/F ratio. If you can find a chart that shows the relationships of this temp to A/F, then just buy one of those infared temp measuring guns, and start having fun!
Regards
Special Ed
________
________
Old 03-29-2006, 11:18 AM
Jerry Clayton's Avatar
Inovate LM1 little under 400--you can get a tailpipe adapter but I would suggest welding a bung
Ours fell out of the side pipe on a test drive one day and skinned it up some
Jerry
Old 03-29-2006, 01:33 PM
Banned
Jerry, thanks for the reference!
Old 03-29-2006, 03:31 PM
Hotfingrs's Avatar
I use the LM-1 and bought the aux box and tailpipe clamp. I monitor, A/F EGT and RPM. Play back on the computer and you can really pick and choose segments and see exactly what's going on.....A little more than 400.00 though.....but well worth it.
Jack
XSSIVE .....
