Go Back   Club Cobra > General Discussion > Registration Forum
Old 11-23-2009, 10:11 AM
Cobra Make, Engine: Integrity 351 Windsor - moderately modified.
Default Starter problem
I have a starter problem, it has happen twice both times the starter has
engaged with the flywheel while the car is moving making one hell of a noise it will last about one minute and stops. I get it home and try to re-start the motor and the starter does nothing. A friend said it's a intermittent short in the ignition switch, causing the solenoid to engage. Any other Ideas before I change the starter and switch??
Old 11-23-2009, 10:26 AM
Gunner's Avatar
I'd start with thoroughly testing the switch. Make sure the beast is in neutral. Turn the key to ON, and then jiggle the hell out of the key and the wiring behind the switch. If you get even a flicker of starter action, the keyswitch is bad.
You're likely to have some damage to the starter pinion teeth and possibly the flywheel. Once you sort out the electrical problem, you might want to inspect both carefully.
This is, er, an odd forum to post the question in.
