12Likes
10-22-2010, 05:44 PM
chassis plans
looking for info,plans ect for a 4" diameter chassis. can anyone help?
10-22-2010, 07:25 PM
fl
Cobra Make, Engine: scratch building
plans
Cobra restorers are about the only avaliable that I know of...used them to build my frame...seemed pretty accurate for what I needed...My gallery has pics of completed frame set up for a 351 and a T-5 with a jag rear.
10-22-2010, 08:19 PM
Nick, where are you?
Alba gu brąth
10-22-2010, 10:12 PM
I'm here but I don't know what a correct set of plans is worth ;-)
10-22-2010, 10:49 PM
Full Blown Member
Cobra Restorers has a full set of plans.
At least they used to. Give them a try.
rodneym
10-23-2010, 06:48 AM
Cobra Make, Engine: CSX2498 has been in our family garage since '68....Scratch built aluminum bodied 427SC Cobra, 427FE, CSX3000 chassis specs, 95% finished, only needs paint.
plans from Cobra Res
Hello CSX, I sent you a PM about the 427 chassis plans. I just finished building a 427 from the plans and do not need the prints anymore.
If I was gonna build another 427 I would buy a finished chassis from one of the vendors and save a lot of time and money. I would start with Acton Custom, Nick knows more than most about building a Cobra from scratch.
this is what it looks like ready for a alum body.
regards, karl
Reason: add foto
10-24-2010, 02:41 AM
I did get 3 chassis built, and it took about 100hours to weld IF you have the laser cut brackets. I strongly recommend to buy one, even though it is fun to weld - but can also be frustrating. 100hours bear plenty of opportunity to get annoyed! ;-)
It takes much less hours without the birdcage. So it you plan to install a body which is sturdy enough to carry itself (the CSX bodies are not), you may consider to weld a chassis. Or, get a body with birdcage inside (Kirkham).
Yet, I urge you to get the brackets from Nick (mickmate).
One more $1mio advise: The rear gusset for the axle shaft (diameter) is too small for Jaguar universals. I increased such holes to the max - after everything was in. I learned a few new swearwords...
05-31-2011, 01:48 PM
frl
Hello,
I'm looking for frame plans for building a 427.
and want to make a body buck to make a alluminium body.
Can you help me?
Regards Eke
regards, karl
06-08-2011, 05:53 PM
Cobra Chassis Plans
Hi
Im in New Zealand and am tring to build a cobra. I have sent an email to cobra restorers, but have had no reply. I wondered whether it was possible to get a copy of the plans you have. I am prepared to pay.
Otherwise do you know somewhere else to get some plans.
Mark
06-08-2011, 09:06 PM
You're not from NZ or you would have said "g'day", Cobra Restorers are better answering the phone than e-mail. They pop up on e-bay from time to time and there are one or two other formats floating around.
06-08-2011, 09:53 PM
SI
Mark. Are you going to build a coil spring or leaf spring car, or just want a box section/kit car type chassis?
Jac Mac
05-09-2016, 03:24 AM
Registered User
Originally Posted by markp1
Hi
Mark
Hi Mark,
Did you manage to get hold of a set of plans for an AC Cobra?
05-21-2016, 12:58 AM
Interesting to see a few single digit posters, never coming back.
If you intend to build a Cobra from scratch I would expect you guys to post more.
Or y'all bought chassis!
05-21-2016, 02:10 AM
wa
Would love a set of original plans to blow up and hang on the shed wall......would look super cool.
01-30-2018, 07:01 PM
Hey , I'm just butting in now....But I would really like some drawings. I am just finishing a frame off on my Cobra and would'nt mind starting again .
01-31-2018, 02:20 PM
SK
COBRA BLUEPRINTS
427 Cobra Chassis
Nine pages completely detailed and dimensioned prints of the 427 Cobra chassis with all suspension pick up points and differential locating brackets, plus details of body mounting support system. Original blue prints from AC Cars which they used. Does not include A-arms, spindles or uprights.
http://www.parts123.com/parts123/yb....Z5Z5Z50000027b
Brian
02-22-2018, 05:11 AM
Registered User
Building Shelby Cobra from scratch
Hello,
I just joined the forum.
My name is Karan Nawab, I am from India. I am planning to build a Shelby Cobra from scratch. I would request you all to guide me through the chassis plans and specification. It would be great if you could supply me with a Chassis Plan to start with. Thanking you all.
02-22-2018, 02:20 PM
UK
Cobra Make, Engine: DB427SC. 289FIA. COUPE. Round tube, Aluminium body, 427FE
Hi Karen.
I don't think anyone will want to give away their drawings. And even less a set of CAD files for laser cutting.
02-23-2018, 01:21 AM
I can sell the mold I took from a Contemporary. You can make a body from it and use it as a buck to fabricate aluminium bodies.
Parts are in South Africa.
I also have a chassis.
03-01-2018, 10:48 AM
Cobra Make, Engine: CSX3193, replica 289 Cobra and replica Daytona Coupe Cobra
I now offer complete 427 chassis drawings (as well as drawings for the 289 Cobra and Daytona Coupe). Send me an email or check out the details on my website which has been revised and located at the following:
Home
