Like Tree75Likes
Old 05-31-2015, 11:45 AM
1985 CCX's Avatar
Neutral
Another shot of 2317.
The long haul begins.
Old 05-31-2015, 11:51 AM
1985 CCX's Avatar
New FIA style wheels.
Tires are just for build use.
Step one = check.
Old 06-02-2015, 06:59 AM
Thor maine's Avatar
I see you have the ride height set just the way you like it. Just kidding Jeff, 2317 is a beauty can't wait to see the build.
JBCOBRA likes this.
Old 06-02-2015, 09:42 AM
1985 CCX's Avatar
Started collecting parts. The fender mirror is Walpres style bullet.
Picked up a nice patina 30560.
LMH likes this.
Old 06-02-2015, 09:46 AM
1985 CCX's Avatar
Funny Tom, have a spare 350?
Old 06-02-2015, 03:25 PM
Thor maine's Avatar
How about an all aluminum 350 stroked to say 427 C.I. with a FAST EFI tied to a nice 5 speed?
Old 06-02-2015, 06:51 PM
1985 CCX's Avatar
Picked up a washer button.
Will need to paint button beige but that's easy.
LMH likes this.
Old 06-02-2015, 07:48 PM
LMH's Avatar
LMH LMH is offline
Working on a second generation recreation washer switch now. I'm using my original as the pattern and will be casting buttons in correct ivory color soon. (Hopefully!)
Alba gu brąth
Old 06-03-2015, 05:58 AM
1985 CCX's Avatar
Great work.......
Keep us posted.
Old 07-13-2015, 11:21 AM
1985 CCX's Avatar
Larry still awaiting that new button......
Planning to get started next month on the welding of the frame. A local welding shop will provide finished welding so frame can be primed, painted and prepped for the body mounting. The shop is currently moving to a larger shop in July, hopes are that August brings this to completion. Will post pics once we are under way.
Started to discuss a motor with Cobra Automotive. Not sure if I should take the 5 bolt 289 route or go to a 6 bolt 289? Thoughts?
Planning a mild 300hp motor for ease of drive and use.
Any thoughts about 289's (Ford only) and there application?
Old 07-13-2015, 12:17 PM
LMH's Avatar
LMH LMH is offline
Life has been in the way lately and I haven't been able to get with the guy doing the casting. He's up in PHX. Hopefully soon though!
Alba gu brąth
Old 07-13-2015, 05:13 PM
1985 CCX's Avatar
Plenty of time.
How do you put in the button.
Is it a sleeve?
  #33 (permalink)
Old 07-13-2015, 06:10 PM
LMH's Avatar
LMH LMH is offline
Kind of complicated but the button is actually two pieces. The button has a slot in the back that's machined out and a small flat tab fits in it and protrudes into the switch itself.
I have to cast the new buttons and have them micro machined. We copied the bezel using my original as the master, machined them out of brass and had them chromed. Actually a little nicer than the original. Just need more time to get with the caster for the buttons.
I watched an original sell for for $318 last week on eBay!
Alba gu brąth
  #34 (permalink)
Old 08-07-2015, 05:37 PM
1985 CCX's Avatar
Planned glove box door
  #35 (permalink)
Old 08-07-2015, 05:39 PM
1985 CCX's Avatar
Very nice work thanks to my friend David Wagner, can't wait to fit.
  #36 (permalink)
Old 08-17-2015, 01:25 PM
1985 CCX's Avatar
Not planning to use the VC but nice parts to have in stock.....
Early Cobra units... The crystal ball is to help with car #2 foresight.
  #37 (permalink)
Old 08-17-2015, 02:46 PM
CompClassics's Avatar
Cobras use 5-bolt blocks, unless you plan on running an automatic...then a 6-bolt is called for.
  #38 (permalink)
Old 08-17-2015, 03:22 PM
1985 CCX's Avatar
Yup 5 bolt.
T10 4spd for me.
If I went auto I would go Vette.
  #39 (permalink)
Old 09-22-2015, 04:45 PM
1985 CCX's Avatar
Met up with my friend Curt at Cobra Automotive today.
Started power train process
5 bolt 289
Cast iron heads
T10 transmission
Bell housing
Picked out base parts for a simple 275hp style; 289 for this car.
Want drivable, pump gas, solid lifter period type V8.
Cobra Automotive to build the power.
Off to a solid start.
  #40 (permalink)
Old 09-23-2015, 01:33 PM
1985 CCX's Avatar
Exacting parts from Jim Cowles.
