Old 11-13-2006, 06:57 PM
rwall49's Avatar
Cobra Make, Engine: HM Ford 351w
Default brake and fuel lines
Can anyone tell me what they used to connect and separate the brake and fuel lines as they run along the frame. I looked for a double clamp that keeps the two lines separated and also cushioned from the frame and reduces vibrationm but could not find this item. Help if you can.
Old 11-13-2006, 07:15 PM
wtm442's Avatar
Beam Me Up Scottie
Adell clamps are good. I've used them numerous times over the last 30 years or so on many vehicles.
http://www.boatownerswarehouse.com/b...fm/2,4921.html
Warren
Old 11-13-2006, 08:11 PM
vettestr's Avatar
Every clamp and type known to man is here http://www.inlinetube.com/images/bra...lips/clips.htm but I like the rubber cushioned clamps at Jegs too http://www.jegs.com/webapp/wcs/store...10002_23473_-1 part # 361-171003
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
Old 11-13-2006, 08:55 PM
mickmate's Avatar
What diameter lines? I've been giving away some nifty little widgets I have a heap of for two lines.
mickmate
http://www.actoncustom.com/
Old 11-14-2006, 08:04 AM
rwall49's Avatar
Default sizes
the size lines I think I will be using is 3/16 and 3/8.
ron
Old 11-15-2006, 08:17 PM
mickmate's Avatar
The ones I have are for 3/8" lines. If you want some e-mail me some details. You could use a slit piece of rubber tube around the 3/16........
mickmate
Old 11-16-2006, 01:54 PM
Dominik's Avatar
I like the clamps used at the production line for GM or most others.
It's a screw on plastic block (to chassis) where the lines can be clipped into.
I haven't seen them for sale to the general public though!
Dom
Old 12-02-2006, 06:43 PM
rwall49's Avatar
Default clamps for brake and fuel lines
Guys thanks for the info. I have found a link that might be interesting to some.
http://www.tperformance.com/
Look under brake fittings
