Like Tree4Likes
Old 02-15-2008, 07:25 PM
63mercury's Avatar
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
The front will be 56 in from the face of the rotor ( where the wheel mounts) the rear will be 58.250.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
Old 03-01-2008, 06:40 AM
63mercury's Avatar
Just a quick update, got my new saw set up and am really happy with results very straight cuts. Should be making some additions to the pics soon, got more snow so must clean up yard again, todays paper said we had 27 in of the stuff in Feb,not a record just more than normal.
Old 03-01-2008, 06:49 AM
joey_hv's Avatar
Cobra Make, Engine: Joey Manufacturing Inc.
Send a message via Yahoo to joey_hv
wow..27" of snow! crazy, and I'm working in shorts and t-shirts.
"Me fodder was King Neptune, me mudder was a mermaid. I was born on the crest of a wave and rocked in the cradle of the deep. Me hair is like hemp, me arms are like spars. When I spits, I spits tar. I'm hard, I am, I is, I are. "
Old 03-01-2008, 07:38 PM
63mercury's Avatar
There is a place in the Keweenaw peninsula sticking into Lake Superior that had 394 in of snow a few years back, they put a gage up on the side of the road showing just how high it was. That's way too much snow.
Old 03-02-2008, 07:55 PM
63mercury's Avatar
Got the X and upper front shock mounts tacked up today, will try to get pics posted tomorrow, have to buy another piece of tube and the rear will come together, will be making a small change to the rear frame over the axle but nothing serious.
Old 03-10-2008, 08:53 AM
63mercury's Avatar
I have posted more pictures in my gallery more comming, can't remember how to get from photobucker to here with smaller pics, but will keep on trying.
Old 03-21-2008, 07:21 PM
63mercury's Avatar
couple more pics.
Old 03-21-2008, 07:27 PM
63mercury's Avatar
sorry they are small but its all I can get on here big ones are in my gallery.Name:  th_CobraBuild26.jpg
Work is progressing slowly, waiting for the weather to break so I can go to the recycler to get more parts.
Old 03-21-2008, 07:55 PM
fasterpatrick's Avatar
Cobra Make, Engine: scratch build self design 4.6l DOHC
I can
you to select, copy, and paste the link at the bottom of the photo display page into your post.
Old 03-30-2008, 08:22 PM
63mercury's Avatar
Thanks Patrick, I will try that for my next post. I have the cowl hoop tacked up and tack mounted onto the outriggers, modified the tie rod ends to get the toe in set, will order the proper parts for final assembly. will post pics in the next couple days. Will be going to the scrap yard in the morning to check out the T-bird rotors for fit, they are 10.5 in dia and the caliper brackets will allow standard parts to be used ( all Ford no GM stuff). Carl.
Old 04-02-2008, 07:04 PM
63mercury's Avatar
Went to the yard to look at parts and found out they are 4 lug, so I ordered the rotors,bearings, and locknuts from Speedway motors Monday and they arrived tonight via ups. Have posted more in my gallery and will work on the car tomorrow afternoon. Name:  th_CobraBuild52.jpg
Old 06-05-2008, 07:51 PM
63mercury's Avatar
Picked up a 302 to rebuild, needs boring and maybe a stroker to make it 347.
Also picked up a T-5 now I must find the bellhousing and I can do a fitup before I rebuild the engine. The engine came with a set of 1966 heads which have 57cc chambers, this may be something I can work with. Just gathering parts and finishing the honey-do's till the white stuff flies again.
  #33 (permalink)
Old 06-15-2008, 08:00 PM
63mercury's Avatar
Got a bell housing now I can start fitting stuff together and making motor mounts, life is good.
  #34 (permalink)
Old 07-29-2008, 07:32 PM
63mercury's Avatar
I picked up another 302 today from a lincoln with less than 40,000 when wrecked and has been sitting for 20 years, cylinders are, were, full of oil in fact I drained over 2 gal out, have the intake off and its clean as new. I will be removing the heads to check the cylinders and do a port and valve job. I'm waiting for my intake from ebay. Now I need a 50 oz flywheel and the work begins.
  #35 (permalink)
Old 07-30-2008, 06:20 AM
Jay Little's Avatar
Cobra Make, Engine: Undecided, 289
Looks like you are making decent progress. Pardon me while I sit here and be envious! Keep up the good work.
  #36 (permalink)
Old 07-30-2008, 10:37 AM
Juggernaut's Avatar
Cobra Make, Engine: RUCC, 289 c.i. with a T-5 "Living the Cobra Experience"
Looking good, Carl!
It always amazes me seeing a Cobra built from scratch, my hat's off to you!
Juggernaut
  #37 (permalink)
Old 07-30-2008, 08:12 PM
63mercury's Avatar
Thanks guys, my inspiriation has been Fasterpatrick and all the other scratch builders who like me just take the plunge. Carl
  #38 (permalink)
Old 09-03-2008, 07:02 PM
63mercury's Avatar
Another update, got the coil-overs and mounted them, motor mounts are tacked in but need repositioning (motor is too low) and got the dash from a ffr guy, things are comming together. Carl
  #39 (permalink)
Old 11-29-2008, 06:16 PM
stengun's Avatar
Cobra Make, Engine: FFR 4859GT Spyder GT 414W EFI
Send a message via Yahoo to stengun
Howdy Carl,
Thanks for the pics and keep us updated. Since it's winter time, you should be able to get alot of work done.
Paul
"A veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of 'up to and including my life.'" (Author unknown)
  #40 (permalink)
Old 12-01-2008, 07:31 PM
63mercury's Avatar
Hey Guys, I posted this in the classified area but figured more would see it here; I need a T-5 yoke or drive shaft from a Mustang with a T-5 so I can work on my drive shaft. Don't want to buy new if I can help it. Just the old hot rodder in me. Thanks Carl.
