Like Tree62Likes
  #101 (permalink)
Old 12-24-2016, 04:33 PM
map's Avatar
map map is offline
Cobra Make, Engine: Myself/Body from CSX-2575 & hand built Birdcage
Send a message via Skype™ to map
What size pipe did you use? I will be working on a 289 build in the coming months and will need to custom fabricate some pipes. Mine may be more under the car and exiting just prior to the rear wheels.
3" from the collector back I found a great deal on eBay on 3" J bends, the exit/turn down is at the rear wheel arch. Looking at the Speedway Auger style muffler. Dynatech® Auger Style Muffler, 11 x 3 Inch
I can't run the side pipes under the body like 2260 (pic) I built in 1 1/2" of drop into the chassis when I built it I won't have any ground clearance.
1985 CCX likes this.
6S1941
Allied 289 Slab Side
73 2.3 turbo pinto
  #102 (permalink)
Old 12-24-2016, 04:38 PM
map's Avatar
map map is offline
Sweet progress.
You gonna make SAAC42
I doubt it I just about made it to Beaver run 40 miles away.
6S1941
73 2.3 turbo pinto
  #103 (permalink)
Old 01-01-2017, 06:50 PM
map's Avatar
map map is offline
Burp tank.
1985 CCX and LMH like this.
6S1941
73 2.3 turbo pinto
  #104 (permalink)
Old 01-02-2017, 08:15 AM
jolsen42's Avatar
Well done!
John O
jjo42
  #105 (permalink)
Old 01-02-2017, 06:00 PM
1985 CCX's Avatar
You going to fabricate the alternator bracket or go to a current source?
  #106 (permalink)
Old 01-03-2017, 12:08 PM
map's Avatar
map map is offline
It's done I want it low & tight shortest belt possible.
6S1941
73 2.3 turbo pinto
  #107 (permalink)
Old 01-22-2017, 11:38 AM
map's Avatar
map map is offline
Still at it.
6S1941
73 2.3 turbo pinto
  #108 (permalink)
Old 01-22-2017, 11:44 AM
map's Avatar
map map is offline
Thanks for noticing the Alt I screwed up I had it in the wrong place right in the support tube moved now. I made a bracket.
6S1941
73 2.3 turbo pinto
  #109 (permalink)
Old 01-22-2017, 05:04 PM
map's Avatar
map map is offline
Moving along today I got all the Battery tray cut & bent But I can't remember what the battery hold down looks like any Pix?
6S1941
73 2.3 turbo pinto
  #110 (permalink)
Old 01-22-2017, 07:15 PM
LMH's Avatar
LMH LMH is offline
Alba gu brŕth
  #111 (permalink)
Old 01-22-2017, 08:31 PM
map's Avatar
map map is offline
Originally Posted by LMH View Post
Thanks Larry make one tomorrow!
6S1941
73 2.3 turbo pinto
  #112 (permalink)
Old 01-24-2017, 01:34 PM
map's Avatar
map map is offline
1985 CCX and 1795 like this.
6S1941
73 2.3 turbo pinto
  #113 (permalink)
Old 01-31-2017, 11:08 AM
map's Avatar
map map is offline
Moving along.
6S1941
73 2.3 turbo pinto
  #114 (permalink)
Old 01-31-2017, 11:47 AM
1795's Avatar
In my opinion, the sanding and glass work is the worst part Looks like you are doing a good job.
  #115 (permalink)
Old 02-03-2017, 09:33 AM
map's Avatar
map map is offline
Endless!
6S1941
73 2.3 turbo pinto
  #116 (permalink)
Old 02-03-2017, 09:40 AM
map's Avatar
map map is offline
6S1941
73 2.3 turbo pinto
  #117 (permalink)
Old 02-03-2017, 10:45 AM
Bill D's Avatar
Is the hood hoop steel or aluminum? And what size (OD and wall thickness)?
Bill
  #118 (permalink)
Old 02-03-2017, 12:43 PM
map's Avatar
map map is offline
Bill
Bill it's the original 3/4" steel from CSX-2575.
Your Body was made in the mold from my car.
Bill D likes this.
6S1941
73 2.3 turbo pinto
  #119 (permalink)
Old 02-03-2017, 12:51 PM
jolsen42's Avatar
As was mine.
John O
Bill D likes this.
jjo42
  #120 (permalink)
Old 02-03-2017, 03:30 PM
map's Avatar
map map is offline
Originally Posted by jolsen42 View Post
As was mine.
John O
And it's a fantastic Cobra well done john!
So mine had babies.
6S1941
73 2.3 turbo pinto
