Old 12-22-2008, 08:00 PM
Cobra Make, Engine: FFR MKII
Default 4 to 5 lug conversion
Anyone done a 4 to 5 lug conversion and added discs to the rear? Anyone know how I can tell me how to tell my axle spline count without pulling an axle?
Old 12-22-2008, 08:38 PM
PurpleVenom's Avatar
Cobra Make, Engine: FFR MKII - 460 Crate with Cobra Jet heads, 750 Quick Fuel Carb, and Edelbrock Torker II Intake port matched to heads
Check this link - http://www.kevinstang.com/Ninecase.htm
8.8 or 9"?
Old 12-23-2008, 05:07 AM
The easiest thing to probably do is get a set of Moser axles. Have them put the 94+ hub on the axle and the length of the 93 and earlier. You can then run a wider tire if you choose.
If you don't have the later style hub put on, then you will have to make an adapter for the brake rotor as the drum brake hub is smaller.
Get ahold of North Race Cars for the disk brake adapters.
